Hi, Im New Here
28 replies to this topic
#16 redb4 OFFLINE
redb4
  • 39 Thanks
  • 61 posts
Posted May 15, 2013 - 08:02 PM
The Tecumseh 8-18 HP manual is a great one. You could be having carb issues as those carb wear the butterfly shaft or bushings and they suck air. Bet you spray some carb cleaner around that shaft and rpm's will change/smooth out.
Hope you didn't remove the center main jet when you cleaned it. They are screwed in carb, then drilled at factory. Once removed you can't get them lined back up and carb will be too lean and you will get rpm  "surge" or "hunting". There is a way to cut a new cut a new slot in it, can't rememebr where I saw it at, or replacement ones can be bought.
Start with your adjustment screws on jets at 1 1/2 turn out, then fine tune from there.
You called it.  I did remove the centre main jet/emulsion tube.. who knew.  I just ordered a Genuine Tecumseh carb rebuild kit from a local shop.  I know I could have found one cheaper on eBay, but.  I think it's best to support local shops.  A bit more money perhaps, but, so what.
  • TAHOE said thank you
#17 TAHOE OFFLINE
TAHOE
  • 7,950 Thanks
  • 5,667 posts
Posted May 16, 2013 - 11:20 AM
Hopefully that will cure the surge issues.
#18 redb4 OFFLINE
redb4
  • 39 Thanks
  • 61 posts
Posted May 16, 2013 - 06:46 PM
Hopefully the kit has the new "main jet/emulsion tube" in it.  If not, maybe a drill motor and a file can make the needed grove.
Thanks to all for the help.
#19 IamSherwood OFFLINE
  • 8,391 Thanks
Posted May 16, 2013 - 11:21 PM
I don't think the kits had the service nozzle in them.
Here is a source for them. I've bought a couple from them, and had
good results.
#20 UncleWillie OFFLINE
  • 15,661 Thanks
  • 8,758 posts
Posted May 16, 2013 - 11:35 PM
Welcom to the tractor asylum. We are all crazy but it is a good kind of crazy.
:camera: :picsoritsnotyours: :wewantpics: :welcometogttalk:
  • GT5k6spd said thank you
#21 redb4 OFFLINE
redb4
  • 39 Thanks
  • 61 posts
Posted May 17, 2013 - 07:41 PM
I guess I'm daft.  I can't find a way to attach a photo.
H
#22 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted May 17, 2013 - 07:59 PM
Welcome to GTtalk! Thanks for joining! I can't give any advice that has not already been given.
#23 redb4 OFFLINE
redb4
  • 39 Thanks
  • 61 posts
Posted May 17, 2013 - 09:18 PM
Can you tell me how to attach a photo?
#24 MH81 OFFLINE
Posted May 17, 2013 - 09:30 PM
Sure, in the lower right corner of the reply box is "more options"
Click there and at the bottom of the new screen is a spot to choose your pic and upload.
There is one good info here too. http://gardentractor...file-uploading/
#25 GT5k6spd OFFLINE
GT5k6spd
  • 37 Thanks
  • 53 posts
Posted May 17, 2013 - 10:20 PM
welcome!
#26 redb4 OFFLINE
redb4
  • 39 Thanks
  • 61 posts
Posted May 18, 2013 - 10:05 AM
Here is a photo of my SS12 I took the same day I got it.  The photo is upside down and I can't find a rotate function.
Edited by MH81, May 18, 2013 - 10:22 AM.
photo flip
#27 MH81 OFFLINE
Posted May 18, 2013 - 10:23 AM
Nice 12, that's a real workhorse you have there.
Thanks for the pic, I got it flipped for you.
#28 UncleWillie OFFLINE
  • 15,661 Thanks
  • 8,758 posts
Posted May 18, 2013 - 11:16 AM
Nice tractor.
#29 redb4 OFFLINE
redb4
  • 39 Thanks
  • 61 posts
Posted May 18, 2013 - 01:25 PM
Thanks for flipping the photo!
I managed to get it to idle.  I marked the location of the carbs idle passage on the main jet, then I filed a small grove in the jet so that it's drilling could feed fuel to the idle passage.  Seems to have worked, the mixture screw is responsive.  Thanks again for the info.
  • MH81 and TAHOE have said thanks
