Hi, Im New Here
28 replies to this topic
#1 redb4 OFFLINE
redb4
  • 39 Thanks
  • 61 posts
Posted May 12, 2013 - 06:26 PM
Hi, I'm basically new to lawn/garden tractors.  I have a Bolens 1050 with a few extra bits, but the mower is missing to many parts to make it feasible to fix.  I just purchased a Sears SS12, 917.25510, with a mower deck.
The Bolens, I traded work for.  The Sears, I bought.  Nether were to be collectors, I need to mow my lawn.
As you might imagine, I have some questions... I'm sure to be followed by others
Can anybody tell me the part # of the packing "O" ring in the gas shut off valve?  And, or, a possible way to stop it leaking?
Does any one belt maker, make a better belt?
TIA
H
  • Dieselcubmike and JRJ have said thanks
#2 boyscout862 ONLINE
  • 13,556 Thanks
  • 9,430 posts
Posted May 12, 2013 - 07:09 PM
Welcome to GTT. You have two very good tractors. You can download three manuals for free per day in our manuals section. The "o" is probably generic that you can match at an auto parts store or go to Harbor Freight and get one of their "O" Ring assortments for about $10.  http://www.harborfre...result?q=O Ring
Your questions are always welcome and we like to see pictures. Good Luck, Rick
Edited by boyscout862, May 12, 2013 - 07:12 PM.
#3 KC9KAS ONLINE
KC9KAS
  • 5,468 Thanks
  • 4,723 posts
Posted May 12, 2013 - 07:22 PM
Can't help with your questions, but :welcometogttalk:
#4 MH81 OFFLINE
  • 29,979 Thanks
Posted May 12, 2013 - 07:23 PM
Yes, that is a very capable pair of tractors. Some guys in the past would use "packing rope" to replace, but I agree that most places would sell an o ring that would work.
#5 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted May 12, 2013 - 07:27 PM
Welcome to GTTalk.  I would suggest pulling the old o ring and taking it to a good hardware store or a large tractor dealer and having the parts guy match it for you if you don't want to invest in an assortment.
Ben W.
#6 daytime dave OFFLINE
  • 4,967 Thanks
  • 6,598 posts
Posted May 12, 2013 - 08:20 PM
Welcome.  I'd like to see your GT's when you get a chance.  Glad you joined.
#7 Newpaws493 OFFLINE
Newpaws493
  • 1,368 Thanks
  • 1,811 posts
Posted May 12, 2013 - 08:36 PM
TIA
H
Welcome aboard! :wave: Once you get the mowing done, I guess you can get back to collecting :smilewink: Hopefully it won't take much to sort those issues out and oh., :wewantpics:
#8 PaPasTractor OFFLINE
PaPasTractor
  • 197 Thanks
  • 158 posts
Posted May 12, 2013 - 09:25 PM
Hi redb4 and  :welcome: to our group.
I agree with Ben, check a local hardware or if you have a Lowes nearby they have a good assortment of "O" rings.
As far as belts I would say Gates for quality.
Whoops...had to edit...I almost forgot...take some :camera: of your tractors...Thanks
Edited by PaPasTractor, May 12, 2013 - 09:31 PM.
#9 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted May 12, 2013 - 09:46 PM
Hello there and welcome! :wave:
#10 GT5k6spd OFFLINE
GT5k6spd
  • 37 Thanks
  • 53 posts
Posted May 13, 2013 - 12:10 AM
Welcome to GTTalk.
#11 TAHOE ONLINE
TAHOE
  • 8,310 Thanks
  • 5,804 posts
Posted May 13, 2013 - 09:23 AM
I use the Belts I get from Tractor Supply, I only buy the one that are green/blue that have the Kevlar in them.
  • GT5k6spd said thank you
#12 HDWildBill OFFLINE
  • 8,984 Thanks
Posted May 13, 2013 - 11:36 AM
Welcome to GTtalk, redb4.  I think just everyone has covered your questions but feel free to ask as many as you like, a lot of knowledgeable folk on here.
#13 redb4 OFFLINE
redb4
  • 39 Thanks
  • 61 posts
Posted May 14, 2013 - 09:33 PM
Hi thanks for the Welcome.
The packing "O" ring appears to be # 008, it hasn't leaked yet ;)
I went with Dayco belts as they are available locally.
When I first fired up SS12, it was not well.  I cleaned the carb and put it back together.  Made 2 new gaskets, and reinstalled it.  It's way better now.  But I cant get it to idle smoothly.  The governor keeps pulling for more revs.  I don't know if this is normal
Can anybody point me in the direction of a downloadable  manual on how to tune the engine.. Tecumseh 12 HP  sears model 143.592022
Thanks
H
#14 Newpaws493 OFFLINE
Newpaws493
  • 1,368 Thanks
  • 1,811 posts
Posted May 14, 2013 - 11:24 PM
 ... I cant get it to idle smoothly.  The governor keeps pulling for more revs.  I don't know if this is normal
Thanks
H
There are some Tecumseh manuals Here  Hope this helps, goodluck!
#15 TAHOE ONLINE
TAHOE
  • 8,310 Thanks
  • 5,804 posts
Posted May 15, 2013 - 11:50 AM
The Tecumseh 8-18 HP manual is a great one. You could be having carb issues as those carb wear the butterfly shaft or bushings and they suck air. Bet you spray some carb cleaner around that shaft and rpm's will change/smooth out.
Hope you didn't remove the center main jet when you cleaned it. They are screwed in carb, then drilled at factory. Once removed you can't get them lined back up and carb will be too lean and you will get rpm  "surge" or "hunting". There is a way to cut a new cut a new slot in it, can't rememebr where I saw it at, or replacement ones can be bought.
Start with your adjustment screws on jets at 1 1/2 turn out, then fine tune from there.
