Lgt 100-Lgt165 Chassis Differences
8 replies to this topic
#1 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted May 11, 2013 - 08:14 PM
I have a running closed side LGT100
I just emailed a dude about a closed side LGT165, no engine but a lot of attacjhments, wants 250.
How much will swap over between them.
My old 100 runs and drives, but the body is beat off it.
his pics look good, but....
#2 boyscout862 ONLINE
  • 12,855 Thanks
  • 9,173 posts
Posted May 11, 2013 - 08:20 PM
Check the manuals in our section. Just put his body on yours. Attachments are $100+ each. Good Luck, Rick
#3 poncho62 OFFLINE
poncho62
  • 1,751 Thanks
  • 1,665 posts
Posted May 11, 2013 - 08:27 PM
The chassis are set up a bit different at the back for the hydro vs the gear trans.....the attachments should fit with a minimum of work....or put the 10 hp in the hydro chassis.
#4 firstgen89sho OFFLINE
firstgen89sho
  • 82 Thanks
  • 90 posts
Posted May 11, 2013 - 10:49 PM
Depends on what all is there for the Hydro setup. and which way you want to go with it?
Give us an idea and maybe we can help point you in a better direction.
Damn, just looked at the picture of it, that's clean....... I'd easily swap my rebuilt 16 hp into it....
Edited by firstgen89sho, May 11, 2013 - 10:59 PM.
  • Chopperhed said thank you
#5 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted May 11, 2013 - 11:15 PM
I was thinking diesel. PA has an occasional sale on their 10 hp diesels.
Need any parts?
Edited by Chopperhed, May 11, 2013 - 11:19 PM.
  • firstgen89sho said thank you
#6 firstgen89sho OFFLINE
firstgen89sho
  • 82 Thanks
  • 90 posts
Posted May 11, 2013 - 11:45 PM
Need any parts?
For sure....
#7 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted May 12, 2013 - 09:13 AM
For sure....
Just buy it, if you want it, I can't store it right now, I hate to pass it up, but it's just not possible right now.
He also had an ad up looking for an engine from 4 days ago
Edited by Chopperhed, May 12, 2013 - 09:29 AM.
#8 firstgen89sho OFFLINE
firstgen89sho
  • 82 Thanks
  • 90 posts
Posted May 12, 2013 - 01:26 PM
Emailed him, I can get my dad to pick it up if need be. see if it all is still available.
#9 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted May 12, 2013 - 02:00 PM
Good Luck
