Talk About Rough( Case 220 And 155)
12 replies to this topic
#1 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,605 Thanks
  • 1,306 posts
Posted May 11, 2013 - 06:14 PM
Don't ask me why but i wanted them. The 155 is actually very complete. It was being used to mow with (i am told) up until it had problems causing it to die after it ran a while. So he parked it and left it sit out back. The 220 had engine problems,he pulled it out years ago and never got back to it,so it was left out back too. Not real sure what i will do with them yet but most likely will get them going when i get to them. Does anyone know if the 220 should have a holding valve ? The pictures aren't very good ( they are bad ),we unloaded in the rain while it was getting dark and stuffed them in the shed.
Edited by rustyoldjunk, May 11, 2013 - 06:17 PM.
  • boyscout862, dropped82 and Dieselcubmike have said thanks
#2 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted May 11, 2013 - 06:53 PM
So many GT's and so little time!
  • rustyoldjunk said thank you
#3 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,605 Thanks
  • 1,306 posts
Posted May 11, 2013 - 07:07 PM
I know i have them and other antiques in three spots and they are all full....guess i need more space lol.
#4 IlovemyCub OFFLINE
IlovemyCub
  • 172 Thanks
  • 204 posts
Posted May 11, 2013 - 07:11 PM
I say it was a good score! Keep us updated on them! Good luck with them also! Ian.
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted May 12, 2013 - 04:28 AM
Have seen worse.
#6 JDBrian ONLINE
  • 9,604 Thanks
  • 14,142 posts
Posted May 12, 2013 - 05:52 AM
Look at the potential they have not the present condition. They would both be very nice tractors when restored!
#7 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,605 Thanks
  • 1,306 posts
Posted May 12, 2013 - 05:46 PM
You are very right Brian i always see potential in any old iron. The 155 is very complete,even has its side panels and came with a deck. The 220 is a hydro lift tractor and is complete except for an engine and came with two different sized decks. The 155 is the last of the original style Colt/Case tractors and is a late 68 model ( it has out board disc brakes).
#8 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted May 13, 2013 - 09:48 AM
The 220 could have a holding valve, don't think it was standard(maybe later dates) but again it may have one, as it was able to run a tiller.
#9 dropped82 ONLINE
dropped82
    Nut Case
  • 2,448 Thanks
  • 1,795 posts
Posted May 22, 2013 - 04:03 PM
I could solve your space problem and come get that 155. That is a nice score. I've always liked those old 100 series.
Eric
Sent from my XT897 using Tapatalk 2
#10 Ryan313 ONLINE
  • 3,364 Thanks
  • 5,229 posts
Posted May 22, 2013 - 04:18 PM
Just saw this thread, congrats on two nice tractors! Have fun with them! :thumbs:
#11 gizmofixer OFFLINE
gizmofixer
  • 1 posts
Posted December 21, 2013 - 02:47 PM
Hi
I'm looking for a replacement deck for my 155, preferably a 44" but 38 may have to do.
Does anyone know where i might find one??
Thx
-paul
#12 BowlBuilder OFFLINE
BowlBuilder
  • 485 Thanks
  • 465 posts
Posted April 08, 2014 - 04:54 PM
The holding valve being built into the TCV became standard in late 1985.  Yours did not come from the factory with one.  You can purchase either a TCV with holding valve built in and drill new holes or find a suitable holding valve and install it.  About $200 - $250 either way you go.  It is usually best to learn about the different models of holding valves and the different tubing they used so you make sure and get the correct one.  Fortunately, many if not all of the tubes have been reinstated into stock very recently.  New tubes are not cheap, but if you could find a valve for the right price it would be worth it.  Maybe you could find one for sale without tubes real cheap from someone not aware new tubes were recently reintroduced.  If it does have a holding valve already installed, you will see a relatively small rectangular steel device right in front of where the tubes attach to the drive motor.  There will be three very tightly bent tubes connecting things.  I feel a holding valve is necessary unless you have very flat property.  Racing downhill can be frightening.  It should have a "retard " position on the travel control lever which acts as a holding valve.  To use it, the throttle must be wide open and the lever must be properly adjusted.  Refer to your owners manual for info.
  Contact Brian Hildreth for info and prices on tubes.
Edited by BowlBuilder, April 08, 2014 - 04:57 PM.
#13 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted April 11, 2014 - 08:39 PM
   I don't see why you say they are rough, all the tin looks good and straight and all the parts are there. just a little surface rust, overall nice find.  I have a 155 here and love the way it looks.
