Massey Ferg 10 Mower
4 replies to this topic
#1 crokit OFFLINE
crokit
  • 11 Thanks
  • 30 posts
Posted May 11, 2013 - 05:38 PM
As some of you might know, I recently joined the community when I picked up my MF 10.Finally got it dialed in.  What a great little machine.  Drawback on my purchase is it was tractor only; no implements.  Now I'm in the market for a mower deck and mechanics to make it work. Tractor did not come with left side lever etc. In fact, what DO I NEED ??
   Is there someone out this way-Southern Tier of NY- that sells what I'm looking for?  For those unfamiliar, southerntier of NY is roughly Hornell to  Binghamton, Ithaca to Elmira.  Thanks in advance for any help!!
#2 collinmf12 OFFLINE
collinmf12
  • 115 Thanks
  • 198 posts
Posted May 11, 2013 - 07:12 PM
all you need is the mounting brackets that pins on to the fram and they usally come with deck. you will need a belt that goes down from your drive pully to your two other pulleys below. The implement drive clutch is on the right to engage the mower deck. As of selling mowers you can look on ebay. GOOD LUCK!!
  • crokit said thank you
#3 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted May 11, 2013 - 07:27 PM
There are at least 2 types of mower deck mounts used on these.
#4 boyscout862 OFFLINE
  • 13,560 Thanks
  • 9,434 posts
Posted May 11, 2013 - 08:09 PM
Check the manuals here that you can download for free. Then check with our sponsors. Check Ebay, Craigslist, Freecycle, and your local papers. You may have to wait awhile unless you are willing to spend a bunch. There are attachments around that are semi- universal. If your lawn is flat look at a gang mower set. Good Luck, Rick
#5 101 senior OFFLINE
101 senior
  • 249 Thanks
  • 382 posts
Posted May 12, 2013 - 06:44 AM
Paul Jacksons small engines in Seneca Falls, NY should have what you need. He has a web sight.
