Gt235E Won't Start
9 replies to this topic
#1 Schreel OFFLINE
Schreel
  • 1 posts
Posted May 11, 2013 - 02:11 PM
I just serviced my circa 2004 GT235E tractor to start the season.  I had to replace the battery.  It wouldn't ttake a charge and the positive terminal was corroded beyond anything I have seen before.  Started and ran fine with new battery.  The wife mowed the lawn with the bagger as usual for the first mowing.  I then completed oil change, converted deck to mulching mower, lubed, fluids, cleaned, etc.  The mower ran fine without problems.  The mower wouldn't start then nest time.  With key in run position, the lights are sporadic.  The battery light is not always on.  I heard a loud click when trying to start several times.  The mower then started several times.
Now back to same thing.  Nothing when I turn the key.  The green LED light is lit on the circuit board connected to the starter switch.  I suspect this is a starter switch or ignition board problem?  Any help with troubleshooting?  I was unable to locate a wiring diagram to help.
#2 Newpaws493 OFFLINE
Newpaws493
  • 1,368 Thanks
  • 1,811 posts
Posted May 11, 2013 - 02:25 PM
Welcome to GTtalk ! not familiar with your Gt. Any pics , and does it have a solenoid? I'm pretty sure somebody more helpful is on the way. :wave:  Hang in there and rest that hammer down on the workbench :smilewink: Hopefully it'll be an easy fix. Goodluck
#3 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted May 11, 2013 - 02:56 PM
Welcome to GTTalk. Sounds like you have a bad connection somewhere, possibly in the ignition switch itself. I don't have any service info for that model no. Perhaps someone else can help with an diagram of the electrical system. Since the lights are sporadic as well as the starting it could be the ignition switch or perhaps a bad chassis (ground) connection.
#4 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted May 11, 2013 - 03:16 PM
No diagram here either, I would start with testing the battery (just because it's new doesn't mean anything) next remove and clean battery cables and make sure they are tight and the ground is good on frame(remove & clean), next would be tightness of any wire you can see, hopefully that may solve the problem.
P.S. Make sure oil level is to proper level on stick.  (low oil cut out, problem after change ..... )  :thumbs:
#5 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted May 11, 2013 - 05:37 PM
Welcome! :wave:
#6 Trav1s ONLINE
Trav1s
  • 3,581 Thanks
  • 4,557 posts
Posted May 11, 2013 - 07:22 PM
My initial thought was ground or lead going to the solenoid.  I would try cleaning those junctions and give it a try.
#7 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted May 11, 2013 - 07:27 PM
Welcome to GTTalk!
Check the grounds, check the grounds, check the grounds.
Then clean your battery connections.
Check your solenoid connections and starter connections.
Then check the grounds one more time.
If all is good, then the switch possibly could use a replacement.
Ben W.
#8 boyscout862 ONLINE
  • 13,557 Thanks
  • 9,431 posts
Posted May 11, 2013 - 08:23 PM
Welcome to GTT. After solving your problem, check out the manuals that you can download for free. Good Luck, Rick
#9 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted May 12, 2013 - 06:52 AM
where do you find them  ?
#10 boyscout862 ONLINE
  • 13,557 Thanks
  • 9,431 posts
Posted May 12, 2013 - 02:38 PM
Click on the manual tab at the top of the window. Its next to forums. Good Luck, Rick
