Creeper Gear Seal Replacement...here We Come..
1 reply to this topic
#1 IlovemyCub OFFLINE
IlovemyCub
  • 172 Thanks
  • 204 posts
Posted May 10, 2013 - 08:21 PM
Hey guys! I know I'm in the middle of my restoration on my Cub Cadet 122, but theres some bad news :O My sheer pin fell out when I was doing yard work, not a problem. So, I go under my tractor to put it back together and once I got under there, I was surprised. My creeper gear seal is shot, and is leaking prettty bad :wallbanging:  . So, I just bought one a few minutes ago, but man. Replacing the seal in this tranny is going to be like a car transmission. Its going to be tuff. Wish me luck! I'll keep you guys updated on it. Ian  :dancingbanana:
#2 EricFromPa ONLINE
EricFromPa
  • 3,658 Thanks
  • 3,114 posts
Posted May 11, 2013 - 04:04 AM
Take the 4 bolts out that hold the engine in,take the bolt or pin out of the top of the clutch hanger and unhook the clutch rod from the pedal.You will be able to slide the engine and whole drive shaft and clutch forward about 5 inches.Should be enough to slip the new gasket over the short creeper gear.It beats taking the whole rear end out.
Edited by EricFromPa, May 11, 2013 - 04:06 AM.
  • IlovemyCub said thank you
