We got this loader in a trade on a job we did last year. Dad has decided to send it to our mine down in the Caribbean. It was built in Feb. 1986, but really runs great and seems to be pretty tight for that old of a machine. The hour meter says it has 21,836Hrs on it and had a major overhaul on the 3304 at 15,000Hrs. The biggest issue we have right now is that it doesn't have any brakes left on it. I got it up to the shop and started going over it to see what it might need. The brake system uses 2 Master cylinders, 1 for each axle and they are Air over Hydraulic. It also has disc brakes all the way around. I also will need to rebuild the Hydraulic cylinders as a couple of them have slow leaks.
Here is a few pictures of it.
Here is a shot of the front axle, axle seal is leaking.
Master cylinders mounted on firewall.
Parking Brake slave cylinder isn't workng.
One of the locks that hold the pin in is broke and bent.
