Mf14/16 Hyd Question
12 replies to this topic
#1 DH1 OFFLINE
DH1
    Electric Tractors
  • 5497 Thanks
  • 5633 posts
Posted May 09, 2013 - 09:33 PM
The MF14/16 come with hyd lift with a single control.
Is it true that if you run the return line from the factory control valve to the input of a 2nd single control and it's return line to the tank you will have 2 separate controls that can operate 2 separate cylinders?
#2 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted May 09, 2013 - 09:36 PM
Yep!, or run it to a dual or triple spool if ya want!
  • DH1 said thank you
#3 DH1 OFFLINE
DH1
    Electric Tractors
  • 5497 Thanks
  • 5633 posts
Posted May 09, 2013 - 09:39 PM
So why would you want to use a diverter valve to control different hyd cylinders?
Having 2 separate controls would be better wouldn't it?
#4 JDBrian OFFLINE
  • 9682 Thanks
  • 14162 posts
Posted May 10, 2013 - 05:20 AM
I think it may be because diverter valves are cheaper and smaller, so you can place one on the side of a console rather than having to find a larger spot that will allow the second valve. The additional control levers would need to be in a readily usable position as well. You may be better off finding a multi channel valve(maybe from a JD) and replacing the stock one so the levers would be in the same location.
#5 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted May 10, 2013 - 06:51 AM
There really is no room behind the dash, for a second valve, or a 2 spool valve.
On my 16, I put a solenoid operated valve under the seat, and a toggle switch
in the dash.
If you don't care about keeping it looking original, you could mount a 2 spool valve on
top of the left or right fender, or  you could take it a step further, and cut out part
of that fender, and make a cover to conceal the valve, like they did on the
MF1450/1650's.....    I just wish the wouldn't have used plastic, for the cover.
#6 DH1 OFFLINE
DH1
    Electric Tractors
  • 5497 Thanks
  • 5633 posts
Posted May 10, 2013 - 05:42 PM
I wouldn't mind having a single control located on the right rear fender beside the seat for the rear lift, push forward for down, push back for up, just like you find on a full size tractor.
  • JDBrian said thank you
#7 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted May 10, 2013 - 06:54 PM
Are you planning on putting a foot pedal on for the hydro control?
#8 DH1 OFFLINE
DH1
    Electric Tractors
  • 5497 Thanks
  • 5633 posts
Posted May 10, 2013 - 06:57 PM
No foot pedal just use the hand control.
#9 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted May 10, 2013 - 07:04 PM
I'm just thinking about trying to make it easier to operate.
You'd have your right hand full, if trying to operate the 3pt, and
drive at the same time.
How about 2 push buttons on the hydro lever?
#10 DH1 OFFLINE
DH1
    Electric Tractors
  • 5497 Thanks
  • 5633 posts
Posted May 10, 2013 - 07:08 PM
I guess I could put 2 push buttons on the Hydro control and use a 12volt snow plow hyd pump to feed the rear lift cylinder, up and down.
#11 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted May 10, 2013 - 07:12 PM
Do you have one of those?
That would save messing with the deck lift circuit.
BTW, I brought the MF8H home today.
#12 DH1 OFFLINE
DH1
    Electric Tractors
  • 5497 Thanks
  • 5633 posts
Posted May 10, 2013 - 07:26 PM
No I got no snow plow pump, just thinking.
#13 JDBrian OFFLINE
  • 9682 Thanks
  • 14162 posts
Posted May 11, 2013 - 05:41 AM
Doug, have you thought of using an electric actuator to get the second implement lift?
