Cub Cadet 1650 Rear Lift Info?
8 replies to this topic
#1 bigspoon OFFLINE
bigspoon
  • 137 Thanks
  • 99 posts
Posted May 09, 2013 - 02:52 PM
I just got a CC 1650( my first hydro lift tractor). Having problems getting the setup right. ie lift arm. Any info or pics would be awesome. Thanks in advance
  • 14,730 Thanks
  • 15,470 posts
Posted May 09, 2013 - 03:45 PM
bigspoon, Welcome to GTtalk, I can't help you with your questions, but someone will shortly.
I am also moving your thread to the Cub Cadet Forum so it gets seen better by the Cub guys.
#3 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted May 09, 2013 - 06:13 PM
Can you post picture of what you have?
#4 bigspoon OFFLINE
bigspoon
  • 137 Thanks
  • 99 posts
Posted May 09, 2013 - 09:05 PM
I can post pic tomorrow after work, the problem is the lift arm the goes to the rockshaft from the rear lift does it angle up or down? I thoughtf I could figure this out but it doesn't look right to me ( I have the lift arm angled down ) and how is it suppose to be bolted to the rock shaft and the pin position, I know there is a float position.
#5 Cvans ONLINE
  • 6,468 Thanks
  • 6,062 posts
Posted May 09, 2013 - 09:07 PM
Hang on and I will go out and check mine.  :D
I'm back.
The long straight part goes to the back and the curve should be up under the tunnel.
Edited by Cvans, May 09, 2013 - 09:17 PM.
#6 bigspoon OFFLINE
bigspoon
  • 137 Thanks
  • 99 posts
Posted May 10, 2013 - 07:53 AM
Thanks for the info, for some reason this thing as been kicking my butt. LoL
#7 Cvans ONLINE
  • 6,468 Thanks
  • 6,062 posts
Posted May 10, 2013 - 10:01 AM
In the parts diagrams they show the curve down but I for the life of me can't figure how that would work. As long as you have the curved end toward the front of the tractor it will only work one was as I recall. I hope the rest of the lift parts were installed correctly?
#8 KennyP OFFLINE
  • 37,582 Thanks
  • 45,541 posts
Posted May 11, 2013 - 07:15 AM
I believe the curve down is so it will clear parts next to the transaxle. I haven't had a chance to install mine as yet, but I did try to build one a while back and it had to be curved down. Can't remember right offhand what it was hitting on.
  • bigspoon said thank you
#9 Cvans ONLINE
  • 6,468 Thanks
  • 6,062 posts
Posted May 11, 2013 - 10:32 AM
Maybe I will have to go out and crawl under mine and look again. Could be in the dark standing on my head I got up and down mixed up, or was it down?  :oh_shucks:
Edited by Cvans, May 11, 2013 - 10:33 AM.
