10Hp B/s Wood Chipper
11 replies to this topic
#1 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted May 09, 2013 - 05:05 AM
A friend of mine brought down a Troy Bilt wood chipper with a not running 10hp B/S
The only thing read on the tag is 3BSX  3422HT   275385
When you pull the starter rope the engine just spins kind of freely like no comp or load
I know nothing about B/S engines but I'm guessing no comp for some reason
Suggestions or help appreciated
larryd
#2 IlovemyCub OFFLINE
IlovemyCub
  • 172 Thanks
  • 204 posts
Posted May 09, 2013 - 05:22 AM
How new is it? The connecting rod could have broke and the piston is stuck some where in the cylinder. Or you could need new rings. Thats what I suggest is wrong. Ian.
  • larryd said thank you
#3 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted May 09, 2013 - 06:29 AM
Remove the spark plug & see if the piston is rising / falling as you pull the start cord.  If it is, you are looking at stuck valves, blown head gasket or rings.
#4 boyscout862 ONLINE
  • 12,864 Thanks
  • 9,175 posts
Posted May 09, 2013 - 06:48 AM
The stuck valve is common. A little PB Blaster through the spark plug hole may free it up. I have a bent piece of brazing rod that I reach in with to push the valve down. I put Marvel Mystery Oil in my gas to prevent the sticking. Also when you park an engine, turn it until there is compression so that both valves are closed. Good Luck, Rick
#5 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted May 09, 2013 - 07:49 AM
is this a OHV or a flat head motor. if it is OHV he might have a bent push rod or broken lifter
#6 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 09, 2013 - 10:35 AM
Larry, those numbers don't seem to line up with the standard BS format. You might want to take a look here to see if you can find parts or other info. http://www.briggsand.../manuals/engine
#7 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted May 09, 2013 - 10:42 AM
Well gentlemen I believe it's beyond parts It is a OHV
It has a baaaaddddddd rattle in the bottom and piston doesn't moooooove
I believe he needs to find another engine
larryd
#8 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 09, 2013 - 10:48 AM
Sounds like it's toast. Those splitters can run an engine hard. For a cheap new engine I'd try a 13hp clone engine from Lifan which is a good quality engine. I think HD sells them. The 13hp won't have to work as hard.
#9 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted May 09, 2013 - 11:22 AM
I've looking on ebay , how do I know if this engine is tapered or sraight shaft
I can't seem to find any imformation on it other no's I mentioned before
larryd
#10 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted May 09, 2013 - 12:14 PM
Gentlemen I have found these are a new style engine basically generators
larryd
#11 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted May 09, 2013 - 12:42 PM
I believe the numbers you have found are from the emissions label. If it's an OHV engine,  the model, type and code numbers are probably stamped on the valve cover.
Utility%20-%20Valve%20Cover.jpg?mh=165&m
  • boyscout862 and larryd have said thanks
#12 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted May 09, 2013 - 01:09 PM
Thanks achomesteader
larryd
