Nitrogen Question
10 replies to this topic
#1 Racerxxx OFFLINE
Racerxxx
  • 57 Thanks
  • 91 posts
Posted May 08, 2013 - 08:44 PM
Was talking to my neighbor last night about his garden. He has lettuces, spinachs and such that are HUGE. I asked what he did. He uses 34 percent straight nitrogen, sparingly. He sprinkles a small handfull every so often. I need my garden to really produce this year. Ive been using a organic nitrogen fertilzer that is about 5 percent plus some P and K.
Now instead of running out to get some 34 percent can I just throw out some more 5 percent?
For instance:
If I throw out 4 handfulls of 5 percent at the same spot is that 20 percent?
If i throw out 4 handfulls of 5 percent at the same spot is that just a bigger pile of 5 percent?
Is nitrogen application cumulative or constant?
Thanks.
  • larryd said thank you
#2 JD DANNELS OFFLINE
JD DANNELS
  • 3792 Thanks
  • 3907 posts
Posted May 08, 2013 - 09:01 PM
That's a good question and I don't really have an answer for you. My dad gave me 3 bags of  30% nitrogen  he bought on markdown. I had never added any  until this year I spread some and tilled it in.
many plants have different requirements you might want to check out.
  • larryd and Racerxxx have said thanks
#3 wilberj ONLINE
wilberj
  • 5551 Thanks
  • 5737 posts
Posted May 08, 2013 - 10:13 PM
I would say no, more you put more it will stay 5% :D
#4 [email protected] OFFLINE
[email protected]
  • 1302 Thanks
  • 1416 posts
Posted May 08, 2013 - 10:34 PM
He has lettuces, spinach's and such that are HUGE.
What about non leaf type plants? I prefer a balanced blend, timing is everything. :thumbs:
P.S. Excess nitrogen fuels fast foliage growth so that your garden has an appearance of a jungle gone wild :D , but other plant growth suffers as a consequence. Energy for flower growth is redirected to foliage proliferation.High levels also require more water, can burn plants, etc.
#5 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2029 Thanks
  • 3172 posts
Posted May 09, 2013 - 03:35 AM
I wouldn't use the 34% stuff, that sounds like Urea to me. If you add the 5% you are also adding extra P and K. I would use Blood meal myself, it's more organic than the chemical stuff. It won't wreck the soil biology like all the chemicals will. Blood meal is about 12% and wouldn't burn your plants like Urea, and it doesn't have any P or K in it.the only down side is, it may atrack animal because they smell the blood.
#6 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4257 Thanks
  • 5840 posts
Posted May 09, 2013 - 04:10 AM
5% is 5%, no matter how much you use.
#7 Alc OFFLINE
  • 9083 Thanks
  • 8325 posts
Posted May 09, 2013 - 05:34 AM
I heard the same thing that  John mentioned above , that the nitrogen make the leaves grow well but might hurt veggies  like peas , beans  ect .
  • Racerxxx said thank you
#8 Amigatec OFFLINE
Amigatec
  • 2029 Thanks
  • 3172 posts
Posted May 09, 2013 - 06:04 AM
The 5% refers to how much of the nutrients is in the product. If it says 5-5-5, only 15% is nutrients and the rest is filler. Most of your chemical fertilizers are salt based and will deplete the soil of bacteria, and fungus. A portion of these are necessary for good plant growth.
A better approach is to sow rye grass in the garden in the fall and then mow it and plow it under in the spring.
  • Alc and Racerxxx have said thanks
#9 JD DANNELS OFFLINE
JD DANNELS
  • 3792 Thanks
  • 3907 posts
Posted May 09, 2013 - 08:59 AM
I have never used much chemical fertilizer. I have heard too much nitrogen will make tomatoes grow huge vines and not set fruit.
#10 EconChuck OFFLINE
EconChuck
  • 252 Thanks
  • 289 posts
Posted May 09, 2013 - 10:00 AM
Hi,
Let me try to explain something about percentages when used in fertilizer mixtures:
The 5% or 32% percent refer to the contents ratio.
So if I apply 5# of 5% at one point I've put 5%x5#=.25# of nitrogen
If I apply 5 # of a 32% fertilizer I've applied 32%x5#=1.6# of nitrogen.
I'm not sure what a recommended dosage per plant is and that would need to be taken into account
So applying more # of a 5% mixture certainly does not change the ratio but changes the amount of nitrogen applied, which in the end is what you want.
Chuck
  • olcowhand, Racerxxx and freedhardwoods have said thanks
#11 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted May 09, 2013 - 10:46 AM
Hi,
Chuck
Chuck has it right, ratio remains constant, but pounds of N will increase.  Timing of applying extra N is everything.  Applying too much N early will go to vine/stalk proliferation, but applying a small amount at first, followed by additional N near time of, say lets say as with corn, just before or at tasseling, adding a side dress of N will boost the ear size without going to the stalk, as the stalk is at or near maturity.  Same with other crops with fruits, such as tomato, pepper, etc.  I would think early N would be fine with leaf plants such as spinach.  Best is to have a soil sample tested so you know exactly what you need.  Your Extension Service office can do that for you.
  • Racerxxx and freedhardwoods have said thanks
