Help With Ford Door Keypad
12 replies to this topic
#1 jms180 OFFLINE
jms180
  • 2628 Thanks
  • 2150 posts
Posted May 07, 2013 - 08:22 PM
My wife has a 2007 Ford Taurus. We need to reset the door keypad to the factory setting. Does anyone know how to do this. The dealer want $40 to do this. We have the factory code but it doesn't work. Please help if you can.
#2 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted May 07, 2013 - 08:35 PM
When you say factory code, do you mean the one off the sticker on the rh side trunk hinge arm?
Another possible code location:
#3 jms180 OFFLINE
jms180
  • 2628 Thanks
  • 2150 posts
Posted May 07, 2013 - 08:44 PM
The code from the owners wallet card. We looked for the sticker on trunk arm but did not see one. The owners manual says the factory code should work even if a personal code has been set but it does not work. I can lock door with keypad by hold 78 & 90 keys so keypad works.
Edited by jms180, May 07, 2013 - 08:49 PM.
#4 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted May 07, 2013 - 08:47 PM
If you have the wallet card and it's not working, then the module is malfunctioning or the card is the wrong one. I'm still digging for a alternate reset option.
#5 jms180 OFFLINE
jms180
  • 2628 Thanks
  • 2150 posts
Posted May 07, 2013 - 08:55 PM
Thanks for your help I will look for the code under by the brake pedal.
#6 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Okay, we should check all the buttons individually.
Try pressing [7/8] + [9/0] at the same time. Do your doors lock?
Try pressing each button one at a time. Wait for the interior lights to go out, then try the next one. If any one pad doesn't turn on the interior lights, that pad is the culprit. If one of the buttons is malfunctioning, and your code uses that button, then we're up the proverbial creek without a key fob.
This keypad contains 8 wires, some of them run to the control module under the steering wheel. There could be a corrosion issue on one of them.
  • jms180 said thank you
#7 SearsYellow OFFLINE
SearsYellow
    Mower Extraordinaire
  • 514 Thanks
  • 599 posts
Posted May 07, 2013 - 09:01 PM
It's a sticker on the control module. On my truck (Sport Trac Explorer) its under the dash. My sisters Lincoln Navigator it's behind the brake pedal directly behind the fuse box. You can find 100 suggestions online but ONLY one of them is correct.
The best thing to do is locate your control module and look for a 5 digit number.
#8 jms180 OFFLINE
jms180
  • 2628 Thanks
  • 2150 posts
Posted May 07, 2013 - 09:06 PM
Wow! you are the man Cat. The code on the wallet card was not the same as the code under the dash. We bought this car used must have the wallet card from another car. Thank you so much scored some points with wife maybe she will let me get another GT.
Edited by jms180, May 07, 2013 - 09:10 PM.
#9 jms180 OFFLINE
jms180
  • 2628 Thanks
  • 2150 posts
Posted May 07, 2013 - 09:14 PM
You guys are great. This is truly a great forum. Thanks for all the help. :rocker2:
#10 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted May 07, 2013 - 09:15 PM
Might as well start surfing CL right now, never know when the tide could turn the other way.
It is possible the module was replaced at one point, but the original wallet card was kept.
#11 jms180 OFFLINE
jms180
  • 2628 Thanks
  • 2150 posts
Posted May 08, 2013 - 06:48 AM
I lost a few points last night forgot take medications before bed. Its amazing how difficult it is to gain points but very easy to loose points.
Back to the car. We bought the car in 2008 used rental car with 25k miles. Bought it at ford dealer. The dealer sales guy did not know door code so they did something and gave us the code on business card which we lost over the years. We never used the keypad until wife got locked out.
Thanks again
Edited by jms180, May 08, 2013 - 07:40 AM.
#12 Team_Green OFFLINE
Team_Green
  • 2214 Thanks
  • 2305 posts
Posted May 09, 2013 - 12:30 AM
Thanks again
Every time i forget to take meds i tell the wife i'm trying to save us money..
Glad you got the car sorted out.
#13 jms180 OFFLINE
jms180
  • 2628 Thanks
  • 2150 posts
Posted May 09, 2013 - 06:42 AM
You are correct about the money the price of meds are unreal.
