Bmp Lgt-145 Melted Regulator Connector / Repair
6 replies to this topic
#1 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,279 Thanks
  • 4,513 posts
Posted May 07, 2013 - 07:23 PM
Been using BMP quite a bit, and some at night work (Has the 35 watt Haligon lamps). Today I noiiced the voltmeter at 12 V instead of 14, so I did some checking. Yep fried connector. Used the dremal to remove the burnt secton, heat shrink on the single wire. All is fine again.
#2 firstgen89sho OFFLINE
firstgen89sho
  • 82 Thanks
  • 90 posts
Posted May 07, 2013 - 08:43 PM
Yeah, mine did the same thing after I rebuilt the engine, luckly mine is still running fine, but I will need a new regulator as it has burnt some of the terminals off.
  • larrybl said thank you
#3 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,279 Thanks
  • 4,513 posts
Posted May 07, 2013 - 09:10 PM
Luckly the regulator terminals are fine. I think the top connector wasn't fully connected and caused a lot of heat. Top connector is now fully seated. I will keep an eye on this.
#4 KennyP OFFLINE
  • 40,207 Thanks
  • 46,805 posts
Posted May 08, 2013 - 05:13 AM
I had to change out the connectors on the FF regulator. Made a lot of difference at the amp gauge. When I found the wire ends on line, I had to get 20 each, so I have spares for the other tractors as needed.
#5 firstgen89sho OFFLINE
firstgen89sho
  • 82 Thanks
  • 90 posts
Posted May 08, 2013 - 08:15 AM
What would be a price on one of those ends there Kenny?
#6 KennyP OFFLINE
  • 40,207 Thanks
  • 46,805 posts
Posted May 08, 2013 - 06:34 PM
Now I gotta find the invoice. No luck in that right now. As soon as I can find it, I will let you know!
Found the e-mail! They are the Packard 56 ends, $0.28 each. But shipping was a bit high.
#7 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted May 08, 2013 - 07:55 PM
If you are willing to accept a non original part, female spade lug connectors are easily available cheap at Crappy Tire, Princess Auto, Radio Shack (the source) or I can send you as many as you need.
