316 John Deere
10 replies to this topic
#1 kenny57 OFFLINE
kenny57
  • 3 Thanks
  • 6 posts
Posted May 07, 2013 - 04:34 PM
i have a jd 316 that keeps throwing pto belt. as soon as clutch engages belt comes off.
#2 DougT ONLINE
DougT
    Dog Approved
  • 7,152 Thanks
  • 5,103 posts
Posted May 07, 2013 - 05:17 PM
Welcome to the forum. Have you replaced the belt with the correct one? Have you checked all the pulleys to make sure there isn't a sloppy bearing? Does this have the spring loaded idler for the tension? Does it move free?
#3 olcowhand ONLINE
  • 43,182 Thanks
  • 32,014 posts
Posted May 07, 2013 - 05:20 PM
Also, inspect the belt closely.  If it has a busted cord, then it'll come off every time.  If there's a spot in the belt that just doesn't act/look like the rest of the belt, (twisted/curved) then it has busted cords & is a goner.
#4 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted May 07, 2013 - 05:44 PM
Where does it throw the belt?  At the engine or at the deck pulleys?
Ben W.
#5 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted May 07, 2013 - 05:54 PM
belts.jpg   You meant on the mower!
#6 Guest_gravely-power_*
  • Guests
Posted May 07, 2013 - 05:58 PM
Sounds like a frozen or stiff Idler pulley.
#7 kenny57 OFFLINE
kenny57
  • 3 Thanks
  • 6 posts
Posted May 07, 2013 - 06:40 PM
the belt is coming off pto clutch. I had it where the pto switch was turned on the belt would stay on untillthe blades started cutting the grass. There is a box with a pulley on each side and a tension adjustor knob. The belt has some wear. i bought a new belt but it was the wrong one. Another trip to town.
#8 jimbobbillyray OFFLINE
jimbobbillyray
  • 3,213 Thanks
  • 2,951 posts
Posted May 07, 2013 - 06:45 PM
That box with the pulley on each side is the mule drive.  Those pulleys can go bad too.  with the mower deck drive belt off of it, spin each by hand, listen to how much noise they make.  If one of them is squalling some yu might replace it too.  Go online or go by your local JD dealer.
#9 kenny57 OFFLINE
kenny57
  • 3 Thanks
  • 6 posts
Posted May 07, 2013 - 06:52 PM
thanks, i will check the pulleys and belt.
#10 kenny57 OFFLINE
kenny57
  • 3 Thanks
  • 6 posts
Posted May 10, 2013 - 07:44 AM
I put a new belt on, and took care of the problem. Thanks for your help.
  • olcowhand said thank you
#11 olcowhand OFFLINE
  • 43,182 Thanks
  • 32,014 posts
Posted May 10, 2013 - 08:33 AM
Had some busted cords as I figured.  Been there myself.  Thanks for updating!
