G4200H - Rc40G Front Links
g4200h rc40g links mower deck
19 replies to this topic
#16 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted May 13, 2013 - 04:39 PM
Now that is what you can call next day service, can't beat that.
Dick
  • Cvans and jmitchl have said thanks
#17 jmitchl OFFLINE
jmitchl
  • 22 Thanks
  • 31 posts
Posted June 10, 2013 - 08:23 AM
Just a quick update. This pic shows how badly misformed someone had made the links. The top one is the correct one. But after using the measurements Cvans supplied, I was able to get them right. The only change was for the deck I have I needed to shorten the longer part of the arms by about 1-3/4 inches. But now the deck rides properly under tractor and I can mount in correct lift arm holes so I now lifts level instead of nose down. Thanks again Cvans.
Edited by jmitchl, June 10, 2013 - 08:24 AM.
  • olcowhand said thank you
#18 Cvans ONLINE
  • 7,126 Thanks
  • 6,304 posts
Posted June 10, 2013 - 08:43 AM
Glad it worked out for you. I hope you get a lot of trouble free use out of your tractor.  :thumbs:
And thank you for the update. It's always nice to know how things turned out.
Edited by Cvans, June 10, 2013 - 08:44 AM.
  • jmitchl said thank you
#19 olcowhand ONLINE
  • 42,469 Thanks
  • 31,825 posts
Posted June 10, 2013 - 09:30 AM
If the all-thread gives on you (1/2" all-thread really just gives you about 3/8" of solid center) , then I'd go with solid rod, then thread the ends.   You could also add a small gusset at the bends to reinforce them.
#20 jmitchl OFFLINE
jmitchl
  • 22 Thanks
  • 31 posts
Posted June 10, 2013 - 10:00 AM
Thanks olcowhand, I was going to watch em close. I know these aren't as strong as what is OEM, but its what I had on it her when I bought it. At least it functions properly now.
Jim
  • twostep said thank you
Also tagged with one or more of these keywords: g4200h, rc40g, links, mower, deck
