Wanted
Need Briggs Starter For Ci Engine
No replies to this topic
#1 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted May 06, 2013 - 07:07 AM
Have Speedex 1430 with a 16hp Briggs ( I think, can't find ID stamp or tags). I need a starter that has the wider mount lugs. Briggs number is 396306.  The shroud on engine's with this starter also have a bump out tin that may unscrew and I also need that. Would consider the whole shroud if that is way you wish to sell. Starter is about 6" long, a longer case than most. Here's a pix of a kit I found on ebay. Was looking for less expensive used one hopefully.  glperry4 at yahoo dot come works or PM on here. Phone 260-358-8401  Huntington, IN
