12Hp Briggs And Stratton Knocking
4 replies to this topic
#1 MR Simplicity 6111 OFFLINE
MR Simplicity 6111
  • 14 Thanks
  • 44 posts
Posted May 06, 2013 - 01:13 AM
Hello,
My 12hp B+S has a knocking noise that emits from the engine when given more than 1/3 throttle, there is no
knocking noise in the lower RPM range, only higher rpm. What could this be? My thoughts are that it is worn bearings.
Thanks
#2 MH81 ONLINE
  • 29,234 Thanks
  • 29,420 posts
Posted May 06, 2013 - 04:53 AM
I am thinking worn bearings too, might check valve clearance tho.. If rod, i would assume the noise would be there all the time. My FIL had a low speed knock on his Cub rider... Ended up all 4 bolts holding the engine down were loose.
Edit: anything out of whack with the shaft drive? Something out of balance at low RPM's?
  • MR Simplicity 6111 said thank you
#3 pharmer ONLINE
pharmer
  • 774 Thanks
  • 727 posts
Posted May 06, 2013 - 05:35 AM
Mine did that on my 212-5 Wheel Horse and next thing I know the rod was in pieces and a hole through the case. I had the case welded and rebuilt the motor. Been using it for the past two years. You may want to check the rod now before a simillar event takes place. Welding an oil saturated case is not an easy task.
  • MH81, Alc and MR Simplicity 6111 have said thanks
#4 New.Canadian.DB.Owner OFFLINE
  • 2,301 Thanks
  • 1,478 posts
Posted May 06, 2013 - 06:59 AM
Is it a Syncro-Balanced unit?  I've had the syncro bearing wear out and I've had the dog bone break.  Both will give you an evil knocking.
#5 MR Simplicity 6111 OFFLINE
MR Simplicity 6111
  • 14 Thanks
  • 44 posts
Posted May 06, 2013 - 12:26 PM
I will check all bolts are tight, and it is smooth when idling. As MH81 said i wouldn't think it would be a rod waiting to be launched out the engine because it is only at a certain rpm range., and yes, it is syncro - blanced.
Cheers for the help
Edited by MR Simplicity 6111, May 06, 2013 - 12:27 PM.
