Caterpillar Won't Start!
8 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 05, 2013 - 09:20 PM
Just put the new electric fuel pump on the Caterpillar today and it has fuel, it has spark, and it does every thing but start and run. Took out a plug and the plugs aren't wet, but the cylinder looked dry. I know that it is getting fuel to the carburetor. And I know the tractor run previously to the fuel system modification. It was running on April 27 just fine, I had witnesses. I drove it into the shop the next day. I took off the fuel pump, vacuum type, and installed an electric fuel pump on the chassis. I can not get the thing to start if It were life and death. I finally gave up after getting fuel air mixture in the face, don't ask why I stood over the open spark hole and cranked the engine. But I am telling you this so no one else is as stupid as I was today. Now, please help me make this thing start.....
#2 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,240 Thanks
  • 5,551 posts
Posted May 05, 2013 - 09:22 PM
Isn't the factory fuel pump part of the carb?
#3 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 05, 2013 - 09:23 PM
No, the factory fuel pump that was integrated into the carburetor has been bypassed and no longer exists, and never will again.
#4 MF10Ryan OFFLINE
MF10Ryan
  • 244 Thanks
  • 74 posts
Posted May 05, 2013 - 09:36 PM
Does that carb have an electric shut off?
Edited by MF10Ryan, May 05, 2013 - 09:36 PM.
#5 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,240 Thanks
  • 5,551 posts
Posted May 05, 2013 - 09:42 PM
 How did you do that, looking at the manual it doesn't seem possible.???
#6 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Nope, never has, never will.
#7 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 05, 2013 - 09:44 PM
It has been done. if you're looking at the carb fuel pump, they came in on the left of it don't know how many mods, don't care cause it works.
#8 Alc OFFLINE
  • 6,742 Thanks
  • 7,396 posts
Posted May 06, 2013 - 05:49 AM
Casey I would try another plug even though you just used the tractor  , I would hate to see you beat yourself up and fine out it was a bad plug . Myself I would also give it a small shot of starting fluid . Just to rule out fuel .
#9 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 06, 2013 - 05:27 PM
It runs... don't know why, don't care, as long as it is.
Edited by wvbuzzmaster, May 06, 2013 - 05:27 PM.
