Starter Motor
6 replies to this topic
#1 massey 16 OFFLINE
massey 16
  • 4 Thanks
  • 38 posts
Posted May 05, 2013 - 06:15 PM
My friend bought a massey 16 at an auction sale the other day it was sold as is and not running . It appears that the owner before put a new starter on. Today we went to try to start the massey and the stater turned but not the flywheel it does not appear to even touch the flywheel is there any adjustment for these starters.
#2 KennyP ONLINE
  • 40,957 Thanks
  • 47,139 posts
Posted May 05, 2013 - 07:28 PM
Is it possible the starter gear did not 'come out' to meet up with the flywheel? Might be stuck in the return position. Try a little spray lube on it.
#3 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,270 Thanks
  • 6,073 posts
Posted May 05, 2013 - 07:41 PM
Is the starter spinning the right way??  Maybe the battery cables are reversed..  Make sure the positive goes to the solenoid's big terminal  Just a thought
So I stand corrected  v v v v
Edited by WNYTractorTinkerer, May 06, 2013 - 03:28 AM.
#4 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted May 06, 2013 - 03:19 AM
Polarity means nothing to a starter, it will spin the same way no matter how its wired.
#5 MH81 OFFLINE
  • 29,979 Thanks
Posted May 06, 2013 - 04:20 AM
I went looking for a good explaination of bendix systems and found this
Now, keep in mind the bendix is exactly backwards on the starter in this video. When you hit the key on that Massey, the spinning shaft drives the bendix gear out and it engages with the flywheel. When the engine fires, it drives the bendix gear back
#6 HDWildBill OFFLINE
  • 8,984 Thanks
Posted May 06, 2013 - 08:41 AM
Check to see if you have the correct starter first.  I have a friend who bought a starter once and he had the same problem.  When I checked it was the wrong starter for his tractor.  If it is the correct starter take it out and bench test it.  Make sure the bendix is in fact working like it should.  Did you check and make sure the engine is free to turn?  Also check all your connections and make sure you have 12V going to the starter.
Another thought is check the cold cranking amps of the battery.  I had a tractor last month that came in with a new starter but wouldn't turn the engine over.  Pulled the stater and bench tested it and it was fine.  Put it back in and the same thing.  Put a slow charge on the battery and one minute it would turn the engine and the next it wouldn't.  Did some research and figured out the battery was to light for that application.  Put stronger battery in and worked fine.
#7 massey 16 OFFLINE
massey 16
  • 4 Thanks
  • 38 posts
Posted May 08, 2013 - 06:29 AM
I have tried lubing the starter and a nother starter than while doing other work on the tractor i had then spark plug out and then turned the key with no spark plug the engine turns over I have also tried diffrent batterys that I know are good. Could the be a bad connection.?
