New Tiller And Bagger Vac Pulleys
34 tiller gt-19
7 replies to this topic
#1 Wm McNett OFFLINE
Wm McNett
  • 126 Thanks
  • 169 posts
Posted May 04, 2013 - 08:42 PM
Here's the pulleys I made for my GT-19
IMG 20121014 092640
IMG 20130417 042729
IMG 20130417 042718
IMG 20130417 042657
  • hamman said thank you
#2 KennyP ONLINE
  • 38,420 Thanks
  • 45,955 posts
Posted May 05, 2013 - 07:08 AM
Looks like that should work!
#3 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1,088 Thanks
  • 1,284 posts
Posted May 05, 2013 - 08:52 AM
Hi. Look beefy. I see you went from a one to a two pulley system. What's your end use for the two pulleys now? Thanks for sharing.
#4 shorty ONLINE
shorty
  • 5,496 Thanks
  • 5,267 posts
Posted May 05, 2013 - 11:20 AM
Nice fabrication on the pulleys. And a vac too. How about pic of it. Wow, you have some neat attachments!
#5 Wm McNett OFFLINE
Wm McNett
  • 126 Thanks
  • 169 posts
Posted May 05, 2013 - 02:22 PM
the single pulley is for the bagger vac
heres the bagger vac on the old New Holland stuck in the ditch
New Holland
the double pulley is for the 34" tiller
heres the tiller I'm rebuilding
IMG 20130422 193536
If you want specific pictures I take requests ;-)
  • shorty said thank you
#6 Keepitsharp OFFLINE
Keepitsharp
  • 2 posts
Posted May 28, 2013 - 04:17 PM
Bill, very nice pulleys!  I have been tracking down a double pulley setup that I am missing for my 34 inch Ariens 831006 tiller.  Did you end up using the splined coupling, PN 1-1561 from SurplusCenter dot com and a 2AK34x1 3.45 inch pulley?  Is that a cap you welded onto the open end?  Thanks!  Great work!  I'd like to give this a try.
#7 Wm McNett OFFLINE
Wm McNett
  • 126 Thanks
  • 169 posts
Posted May 28, 2013 - 05:48 PM
Yes, 2AK34X1, that splined coupler, and their 6" splined on one end shaft to line it up, had to counterbore the side with the coupler about 1/4" so I probably didn't really need the shaft, then I turned a headed plug that fit inside the pulley and bottomed out on the coupler
I'm guessing a piece of 1" round stock with a 1/32" over 3/8" hole would have worked just fine for the headed plug, Just so long as it bottoms out on the PTO shaft and is welded to the pulley, and I could have cut 1/4" off the coupler and not had to put the pulley in the lathe.
Oh, I should add that I have also replaced the pulley on the tiller with a 2AK51X3/4 and to get the 2 lined up is the reason I counterbored the pulley 1/4". puts the PTO shaft 1/4" into the pulley
You may need to go more. Maybe shoot for 3/8" or 1/2" and use some washers to shim it back out if need be.
Edited by Wm McNett, May 28, 2013 - 06:58 PM.
  • Keepitsharp said thank you
#8 Keepitsharp OFFLINE
Keepitsharp
  • 2 posts
Posted May 29, 2013 - 07:38 AM
Thanks very much for this information.  Again, nice work.  Beyond my fabrication capabilities, but I understand what's needed.
Also tagged with one or more of these keywords: 34 tiller, gt-19
