Engineering Marvel......!
10 replies to this topic
#1 hamman OFFLINE
    Homelite Owner Extraordinaire
  • 6,483 Thanks
  • 2,875 posts
Posted May 04, 2013 - 08:25 PM
I was helping my son service a Huskvarna 20 hp, 2042 LS LT / GT of a friends. When we went to drain the oil the whole drain plug came out!!  I notice that it is not supposed to. Now I'm not used to working on something this new so it threw me for a loop. DSCF4209.JPG It has the plastic cap that you twist a 1/8 turn and pull out after you attach a tube to it to drain the oil. As I said we twisted on this and it unscrewed out of the block. It taked a 23mm deep socket I believe. I used a wrench to get it back in tight. but I am not convinced that B & S had a better idea with this, Took about 45 min longer to finish the job than it should of. Just a little rant on my part. Thanks. Roger.
  • IlovemyCub said thank you
#2 KennyP ONLINE
  • 39,149 Thanks
  • 46,321 posts
Posted May 04, 2013 - 08:34 PM
That would have been real good if you had been mowing and it came out!
  • hamman and superaben have said thanks
#3 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted May 04, 2013 - 08:57 PM
I haven't figured out what was wrong w/ the pipe plug or cap on a nipple.
  • hamman said thank you
#4 hamman OFFLINE
  • 6,483 Thanks
  • 2,875 posts
Posted May 04, 2013 - 09:07 PM
It is designed to be able to drain the oil witout taking the plug completely out of the engine. The plastic piece with the cap on it is subbosed to turn 1/8th turn to the left and then be pulled out to allow the oil to drain, after you have placed a tube on it. In this case the whole piece came out of the engine with my fingers. We only used a wrench to tighten it back in after applying teflon tape (approved for oil) to the pipe and screwing it in. It shouldn't have come out that easy. Thanks. Roger.
#5 8tyman8 OFFLINE
  • 415 Thanks
  • 731 posts
Posted May 05, 2013 - 12:12 AM
They are a Joke its Really fun when it opens well your using the Machine dumping ALL the oil out of the engine and causing is to seize
#6 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 05, 2013 - 05:39 AM
Easy oil changes = good idea. Poor execution of good idea = seized engines and angry customers!
  • hamman and MailmAn have said thanks
#7 Kurtee OFFLINE
  • 585 Thanks
  • 467 posts
Posted May 05, 2013 - 01:34 PM
I gotta sat that I bellieve that is not a Briggs item. I have one on my Miller Trailblazer on the end of a hose that pulls out to drain. OEM Miller. The hose allows you to get it out over a pan when draining. That has a Kohler. I am assuming that whoever installed it did not tighten it correctly.
#8 HDWildBill OFFLINE
  • 8,975 Thanks
Posted May 05, 2013 - 01:47 PM
I believe Kurtee is correct.  I've seen them on Kohler's a well.
#9 LilysDad ONLINE
    Millennium Falcon
  • 13,533 Thanks
  • 9,898 posts
Posted May 05, 2013 - 02:36 PM
That's what Loctite is made for.
  • 8,027 Thanks
  • 5,702 posts
Posted May 06, 2013 - 08:24 AM
I've gotten the un-pleasure of working on some JD lawn tractors recently, one had Kohler with that, another had a Kawasaki with it. Both were turn 1/8 turn and pull. Luckily the main tube was tight in block.
#11 BairleaFarm OFFLINE
  • 1,354 Thanks
  • 1,783 posts
Posted May 06, 2013 - 11:42 AM
I love them but they are loose enough I check before I start the service.
Sent from my HTC One VX using Tapatalk 2
