White Smoke From My Engine
6 replies to this topic
#1 lyall OFFLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted May 03, 2013 - 05:24 PM
searching the web I found this site - it has some good info
http://pkjones.hubpa...-engine-smoking
I bookmark it for the future to check back to.
hope this helps others with the problem of white smoke after your garden tractor or any thing else that has been setting for a while
  • Gtractor, Texas Deere and Horse, JDBrian and 6 others have said thanks
#2 Jack OFFLINE
Jack
  • 1,290 Thanks
  • 857 posts
Posted May 03, 2013 - 06:18 PM
Some good info there.  Thanks.
#3 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted May 03, 2013 - 07:12 PM
Now I'm confused.  I always thought white smoke was caused by water in the gas or running lean, while blue smoke was oil.
#4 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted May 03, 2013 - 09:08 PM
lots of good info there i also bookmarked it
#5 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,771 Thanks
  • 4,263 posts
Posted May 04, 2013 - 04:31 AM
means: the new GT-pope is elected :smilewink:
  • lyall and JDBrian have said thanks
#6 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 04, 2013 - 06:09 AM
Nothing like advice from someone who deals with this stuff every day. Thanks for posting the link.
  • lyall said thank you
#7 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted May 04, 2013 - 09:37 AM
never heard of that before.  White smoke is caused by water in the system not breather failure. If the breather failed the motor would not run right or at all.  I have been working in small engine shops for couple years now
