My New G14
19 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted May 01, 2013 - 07:02 PM
Maybe it's a g14. It needs a gasket for the top of the transmission. It's got fast fresh gas in the tank. This for robbed parts so who knows what its missing other than engine tins. If anyone has extras let me know. I don't think this deck goes to this tractor. The ptos are different. he thought he was getting a better deal so he through in some baby ags. He even had the rear diff pin. Pics say a lot so here you go....
Sent from my HTC One VX using Tapatalk 2
#2 superaben OFFLINE
superaben
    Con Man
  • 7672 Thanks
  • 5677 posts
Posted May 01, 2013 - 07:14 PM
Not bad, can't help you on what it is, though.  The grill looks sort of Bolens.  The IH logo certainly helps the appearance either way!
Ben W.
#3 Newpaws493 OFFLINE
Newpaws493
  • 1390 Thanks
  • 1818 posts
Posted May 01, 2013 - 07:24 PM
Yeah pics say a lot but what're they sayin? What have they done?!? Offhand I'd say you ended up with a bunch a parts too.. :(
It's something to work with, once it's sorted out. bent gear shift, plunger style park brake, PTO going North/south..?
:reading_the_manual:  :say_what: Idunno... :(
#4 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted May 01, 2013 - 07:37 PM
Not sure what all the levers do. I must say the only thing cobbled up are the tire chains.
#5 Newpaws493 OFFLINE
Newpaws493
  • 1390 Thanks
  • 1818 posts
Posted May 01, 2013 - 08:06 PM
I'm starting to rethink my reaction as I've never seen the controls on a G14, aside from the welding on the pbrake, the others may be right.?
#6 Arti OFFLINE
Arti
  • 1494 Thanks
  • 1058 posts
  • Location: South West Wisconsin . Now in North Central Mo.
Posted May 01, 2013 - 08:29 PM
Looks like a neat old tractor don't know what it is though.
#7 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted May 01, 2013 - 08:40 PM
WOW....now that tire chain approach is certainly a new one for me!  What the heck were they thinking!!!!!  I know nothing about Bolens, but the deck may be correct, as you are missing the front half of the pto shaft, which would mate to the spline shaft on the jackshaft.
#8 HowardsMF155 OFFLINE
  • 3107 Thanks
  • 3091 posts
Posted May 01, 2013 - 09:02 PM
That guy is really lucky, he could have had this happen:
Bairlea, be really careful if you start doing anything with those tires.
Edited by HowardsMF155, May 01, 2013 - 09:03 PM.
  • olcowhand said thank you
#9 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted May 01, 2013 - 09:06 PM
Looks to be a G14 (Possibly)
Mid 70's
The deck is original from the time period and was originally black. The Frame on the tractor should be black but the hood should be white (Not an IH :D)
The knob with the custon "T" knob welded on it is the park brake
The Shift lever is in the center, to the right is the Hi/Low and the Lever to the left is the PTO.
#10 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted May 01, 2013 - 09:11 PM
The tires will come off if it runs. I should know tomorrow. Looks like I also need the front driveshaft. ;( hopefully all the linkage is there for the deck. At least nothing is rusted up.
#11 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted May 01, 2013 - 09:55 PM
You should be able to recoup your money by selling the IH emblem on Ebay.
#12 Oregon_Bolens OFFLINE
Oregon_Bolens
  • 149 Thanks
  • 171 posts
Posted May 02, 2013 - 04:47 PM
Actually, I need an IH emblem for by CC582. Give you $20?
#13 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted May 02, 2013 - 05:42 PM
Ok. PayPal davidcobb at hotmail . Com
What's this knob do?
#14 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted May 02, 2013 - 05:50 PM
The starter bendix gear doesn't retract and the carb has gas coming from several different places. The fuel pump is cracked. I dislike Tecumseh as well. Here are my options
1. Repower with the 16hp kohler from my cub and part the cub out.
2. Scrap it or part it out.
3. Use some of the chassis and build a homemade gt. How strong are the rear ends in these?
Either way ill have to repower with a kohler. Matching the correct pulleys could be hard. That's assuming the shaft on the kohler is long enough to even accept the 4 pulleys needed.
#15 Newpaws493 OFFLINE
Newpaws493
  • 1390 Thanks
  • 1818 posts
Posted May 02, 2013 - 06:14 PM
It should be your diff control lock, gives you posi traction.( only hand tighten) You posted a pic with a free wheel pin in hand, do you have one mounted as well?(right rear inner side of hub)
