Electric Lift Help '74 112
5 replies to this topic
#1 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,648 Thanks
  • 1,875 posts
Posted May 01, 2013 - 06:29 PM
Well today was going great. Put new drive belts on my 112 and mounted the tiller. The lift had no trouble lifting. Went to do a test run. It did great! Then lifted the tiller and while turning around the tiller dropped. I shut everything off and tried to lift again. It has no problems lifting but it will not hold the tiller (or anything else) up. When it drops you can hear the motor spinning down. So its not stripped. It won't lock. Is this something in the motor I'm guessing? Repairable? Thanks in advance.
Eric
Sent from my XT897 using Tapatalk 2
#2 Littledeere OFFLINE
Littledeere
  • 1,650 Thanks
  • 1,483 posts
Posted May 01, 2013 - 07:53 PM
I think that some of these had a helper spring you may check to see if it has broken
  • Texas Deere and Horse and dropped82 have said thanks
#3 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,648 Thanks
  • 1,875 posts
Posted May 01, 2013 - 10:51 PM
Mine doesn't have the helper spring. After some reading I found that I need that spring so the tiller doesn't drop. Anyone know where I can find that setup? Thanks
Eric
#4 Texas Deere and Horse ONLINE
  • 14,862 Thanks
  • 15,511 posts
Posted May 01, 2013 - 11:04 PM
Eric, I would check with our site sponsors, I'm sure a couple of them have used one for sale.
Good Luck !!
  • dropped82 said thank you
#5 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,648 Thanks
  • 1,875 posts
Posted May 01, 2013 - 11:11 PM
I sent a couple emails out. Hoping for some good news. I want to work this tiller out good this year.
Eric
#6 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,648 Thanks
  • 1,875 posts
Posted May 27, 2013 - 01:21 AM
Just an update. I got the helper spring setup and installed it tonight. I was really excited to see it work. Well its not helping. It does make it lift easier but when it gets to the fully raised position there is no tension on the spring. So basically no help to hold it. I'm lost here now. Anyone have this setup that can post a pic to make sure I have this spring installed correctly? Thanks!
Eric
