Jd 210 Hub And Axle Bearing
10 replies to this topic
#1 WHdbJD ONLINE
WHdbJD
  • 685 Thanks
  • 515 posts
Posted May 01, 2013 - 02:28 PM
Is it possible to replace the bearing in the end of the transmission housing, without a complete teardown?
I had the 210 jacked up and noticed the rear wheels were wobbly...found the splines on the hubs were badly worn.
The right hub wore the outer seal of the bearing off so now dirt will get in there.
I'm thinking this is probably more than this amateur wants to tackle.  john deere 110 002.JPG
  • 14,796 Thanks
  • 15,495 posts
Posted May 01, 2013 - 02:52 PM
You should just have to pull that side of the axle housing off the trans axle and replace the bearing and seal. You might want to replace the axle and hub if they worn badly. E-pay usually has several for sale as they were shared by several models.
  • Alc and WHdbJD have said thanks
#3 jms180 ONLINE
jms180
  • 1,506 Thanks
  • 1,563 posts
Posted May 01, 2013 - 03:40 PM
I agree with Brian the axle housing should unbolt and come off with axle inside then should be easy to repair.
  • WHdbJD said thank you
#4 WHdbJD ONLINE
WHdbJD
  • 685 Thanks
  • 515 posts
Posted May 04, 2013 - 08:32 PM
Is there a bearing and a seal? Or a sealed bearing?
#5 WHdbJD ONLINE
WHdbJD
  • 685 Thanks
  • 515 posts
Posted May 06, 2013 - 08:53 PM
bump
#6 olcowhand ONLINE
  • 41,052 Thanks
  • 31,392 posts
Posted May 06, 2013 - 08:55 PM
The axle seal resides next to the transaxle housing, where the axle tube bolts on.  Out at the hub end, it is just the bearing there.
#7 WHdbJD ONLINE
WHdbJD
  • 685 Thanks
  • 515 posts
Posted May 06, 2013 - 08:59 PM
thanks, that is what I needed to know!
#8 olcowhand ONLINE
  • 41,052 Thanks
  • 31,392 posts
Posted May 06, 2013 - 09:02 PM
You may want to tilt it a little to prevent any leakage.  The seal is pressed into a carrier if you will that is a separate part.  Then a rubber ring seals around the carrier & is snug sealed when the tube is tightened up.  You'll understand what I'm trying to explain when you get in there.
#9 WHdbJD ONLINE
WHdbJD
  • 685 Thanks
  • 515 posts
Posted May 06, 2013 - 09:07 PM
Thanks again! Going to the Portland swap meet next week, will look for some good used hubs. The hub
splines were badly worn, but the axle splines looked OK.  The cast hubs probably wore out before the steel axle.
#10 KennyP ONLINE
  • 38,242 Thanks
  • 45,869 posts
Posted May 09, 2013 - 04:55 AM
Don't forget the :camera:  :wewantpics:
#11 olcowhand ONLINE
  • 41,052 Thanks
  • 31,392 posts
Posted May 09, 2013 - 02:32 PM
I believe Massey 12 hubs are the same also!
