O Ring Question
6 replies to this topic
#1 NCMau OFFLINE
NCMau
  • 1 Thanks
  • 9 posts
Posted May 01, 2013 - 01:16 PM
I have a JD 425 that has a small hydraulic leak at the lines connecting to the steering valve.  I need to replace the O rings. As shown on the attached pic, the removed O rings seem to flat.
My question is, are the original rings round and became flat over the years or they are flat to begin with. I have replacement standard rings in my shop, but I just don't want to go to the trouble of replacing them twice if they are are not the right ones.
#2 DougT ONLINE
DougT
    Dog Approved
  • 6,855 Thanks
  • 4,953 posts
Posted May 01, 2013 - 01:25 PM
Welcome to the forum. My guess would be that they were round and have flattened out. That's purely a guess. Make sure the rings you use are rated for oil.
  • 14,730 Thanks
  • 15,470 posts
Posted May 01, 2013 - 01:37 PM
First off, WELCOME to GTtalk, glad you joined us here.
Those O-rings were round when they were new and now they are not. That's why they are leaking and or they are cracked. You can use what you have as long as you use the right DIA. O-ring. Good Luck !!
#4 NCMau OFFLINE
NCMau
  • 1 Thanks
  • 9 posts
Posted May 01, 2013 - 04:05 PM
Thanks guys. Just wanted to make sure. BTW, this looks like a great site.
#5 KennyP ONLINE
  • 37,511 Thanks
  • 45,513 posts
Posted May 02, 2013 - 08:06 AM
Welcome to the forum! Glad you got an answer for your issue. Hope to see more of your tractor later on.
#6 olcowhand ONLINE
  • 40,372 Thanks
  • 31,177 posts
Posted May 02, 2013 - 08:48 AM
Yep, started life as round.  Welcome to GTT
#7 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted May 02, 2013 - 09:01 AM
Be sure to use an SAE o-ring. They are a special size not the same as a standard o ring.
Sent by Ducky from my Motorola Droid M
