Local Rednecks At It Again
This topic has been archived. This means that you cannot reply to this topic.
11 replies to this topic
#1 TAHOE OFFLINE
TAHOE
  • 7,809 Thanks
  • 5,610 posts
Posted May 01, 2013 - 12:00 PM
These guys actually have some decent fab ideas, but they cobble everything together and only know how to "booger" weld. I bought the front dump bucket for my suburban from them, after a few mods, it was worth the $75 I paid.
So here is their new creation, kind of neat idea, but I can only imagine the fab on it  i.e. notice the duct tape sealant on the hydraulic line.
http://cincinnati.cr...3753625432.html
#2 twostep OFFLINE
twostep
    Rockstar
  • 1,969 Thanks
  • 2,528 posts
Posted May 01, 2013 - 12:33 PM
yeah, I posted this in the "CL of the day" thread last week. looks like a mess from the word go.
#3 TAHOE OFFLINE
TAHOE
  • 7,809 Thanks
  • 5,610 posts
Posted May 01, 2013 - 01:26 PM
I must've missed your post.
They regularly sell suburbans or home made suburban attachments on CL, mostly with the "honda" clones they get from Harbor Freight, usually a conglomeration of parts, never have hoods on them.
As I said, they do have some good ideas, just carried out in redneck fashion. They doing fencing as,well, their "full time" job so I guess when they have no business, they build this stuff.
Here is the bucket I bought from them, you can see all the junk they use and just throw together. I did some cutting and re-welding, litte better design and works great for me.
#4 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Yes very much cobbled up. But I sure could used that post auger around my place for a few weeks.
#5 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,966 Thanks
  • 9,612 posts
Posted May 01, 2013 - 03:39 PM
What is that vertical 2x2 post that is cut and bent? ..... and what pulls up on that trip lever?
#6 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted May 01, 2013 - 04:13 PM
Must be fun to watch when it hits something and they get caught up it the hoses :bigrofl:
#7 olcowhand ONLINE
  • 40,329 Thanks
  • 31,166 posts
Posted May 01, 2013 - 05:28 PM
If they don't have the relief set real low, if that auger hangs up, someone is going to get hurt mighty bad!  DANGEROUS!
#8 twostep OFFLINE
twostep
    Rockstar
  • 1,969 Thanks
  • 2,528 posts
Posted May 02, 2013 - 08:04 AM
That is my thought, I dont' see any type of safety clutch/slip.
I guess if you got the flow right it could be useful mounted to a 3pt. If they just cobbled it together there is no telling how fast (or slow) the auger spins.
#9 TAHOE OFFLINE
TAHOE
  • 7,809 Thanks
  • 5,610 posts
Posted May 02, 2013 - 08:28 AM
The vertical post held the trip mechanism. They just cut, bent, and then added a strap to the back and welded it all. They originally had a long bar that was connected to a mowing deck lift arm that was bolted to the side of their tractor that raised/lowered and then they had a rope or wire connected to the latch mechanism to trip the dump. I got rid of all that, moved the 2x2 over a bit and now it's a self trip when it get high enough, latch hits my winch arm that sticks out, dumps bucket. Since they do fencing, they uses a privacy fence gate latch. I have to add an extra plate to it as I bent it, but actually a good idea. Works pretty well. I've moved mucho yards of mulch, tons of rock/gravel/dirt, and sometimes actually leave it in dump position, lower bucket on ground and use to grade. After it dumps, I just lower it to ground while reversing and once low enough, the bucket re-latches.
As I said they have some good ideas, just typical redneck execution.
Here it is dumped, maybe you can see how it works, best pic I have
Edited by TAHOE, May 02, 2013 - 08:30 AM.
#10 KennyP ONLINE
  • 37,391 Thanks
  • 45,448 posts
Posted May 02, 2013 - 08:49 AM
That's a simple rear bucket. Hadn't thought of something like that. Thanks for sharing it!
#11 TAHOE OFFLINE
TAHOE
  • 7,809 Thanks
  • 5,610 posts
Posted May 02, 2013 - 11:49 AM
Not sure what to say Larry since it's a "front" bucket :D
It would probably work well on the rear too if it was shortened up and some type of actuator or winch mounted. It would be close enough you could make a handle, just reach around and trip it.
#12 KennyP ONLINE
  • 37,391 Thanks
  • 45,448 posts
Posted May 02, 2013 - 12:13 PM
Duh! I concentrated on the bucket, I guess! :bigrofl:
