Grills Baby!
9 replies to this topic
#1 jdslednut OFFLINE
jdslednut
  • 680 Thanks
  • 851 posts
Posted October 23, 2010 - 02:18 PM
My 214 is lacking a grill and I was wondering if the 300 series and 200 series grills are the same in case I come across one somewhere. Anyone know off hand before I try a search in JDParts. How about engine side panels? Would they be the same? I'm missing my right one. Thanks Much!
  • larryd said thank you
#2 MAV OFFLINE
MAV
  • 110 Thanks
  • 215 posts
Posted October 23, 2010 - 03:22 PM
Some of the grills will depending on the year of your 214 with a 312,314 and 317. Side panels will not. Deere used different designs on the side panels depending on the year. Also on designs and ways they mounted on the grills. Hoe this will help you out and save you some money by not buying the wrong one.
#3 thecoater OFFLINE
thecoater
  • 13 Thanks
  • 111 posts
Posted November 02, 2010 - 12:15 PM
the black is from a 216 the green is from a 314
#4 Mikeemc OFFLINE
Mikeemc
  • 1 Thanks
  • 17 posts
Posted November 15, 2010 - 09:53 PM
look around for a square tube grill ,I know some are out there. I think they look the best , not the stamped metal ones. rare find if you get one.
#5 jdslednut OFFLINE
jdslednut
  • 680 Thanks
  • 851 posts
Posted November 15, 2010 - 09:58 PM
I did find one (the stamped one) on Epay for a good deal actually. It's in pretty good condition. I was quite surprised. Now I have a new grill and a new hitch plate (mine was welded up). I suppose I should concentrate on what's in between.
#6 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted February 13, 2011 - 09:19 PM
Got both ends fixed up? I like the in-between part. Good luck with all of it.
#7 jdslednut OFFLINE
jdslednut
  • 680 Thanks
  • 851 posts
Posted February 13, 2011 - 09:54 PM
Engine's getting a new sleeve and I'm about down to the frame + variator. That might be where she stops before a coat of blitz black. I need to till with her in the spring. Looks doubtful at this point.
#8 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted February 14, 2011 - 12:42 PM
If you pick it up and return it, you can borrow my 214 and tiller...HA!
#9 jdslednut OFFLINE
jdslednut
  • 680 Thanks
  • 851 posts
Posted February 14, 2011 - 02:52 PM
I'll keep that in mind once I master my teleport device. Thanks!
#10 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted April 24, 2013 - 07:54 PM
I cut the 2 outside bars off of my grille on my 314 so they won't rub paint on side panels
larryd
