Kohler K181 Throttle Hookup
19 replies to this topic
#16 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted April 30, 2013 - 07:35 PM
Ok help, does the nut just back off and I rotate it all and retighten or does that throw off my speed??
#17 IamSherwood OFFLINE
  • 8,391 Thanks
Posted April 30, 2013 - 07:43 PM
I think you rotate everything counterclockwise.
#18 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted April 30, 2013 - 07:46 PM
I am working on a tiller with a K161 on it, and the disc has a pin in t to keep it from rotating back past idle. its my understanding after you clamp the cable housing down, you rotate he disc clockwise after it places a bit of spring tension on the throttle arm. You start it up loosen the nut and rotate the lever, until the proper rpm is reached. I had to do some reading myself on it.
#19 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted April 30, 2013 - 07:47 PM
This sounds risky....
#20 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted April 30, 2013 - 07:48 PM
Thats what I thought too. I know when I set the rpm on my K301 I did about the same thing, but it's a bit different.
