Kohler K181 Throttle Hookup
19 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted April 30, 2013 - 06:49 PM
Got another kohler k181 question. Same engines as before, k181s off wheel horse 854 and 855. On the k241 and k301 it hooks to a cam that has a spring between it and the governor. But right now I am not even seeing one place that could happen. I need some experts, either kohler or wheel horse, and I will need pictures cause I'm already lost...
#2 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted April 30, 2013 - 06:53 PM
Casey do you have a picture of what you have or don't have?
#3 IHCubGuy OFFLINE
IHCubGuy
  • 1,500 Thanks
  • 1,579 posts
Casey there is a round disc behind the governor arm on the governor shaft.  There should be a spring hooked between the disc and the governor arm.
I'll dig aroung for some pics.
  • wvbuzzmaster said thank you
#4 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted April 30, 2013 - 07:02 PM
  • IHCubGuy said thank you
#5 IHCubGuy OFFLINE
IHCubGuy
  • 1,500 Thanks
  • 1,579 posts
Posted April 30, 2013 - 07:06 PM
do you have a picture looking at the carb and governor linkage from the side?  That would help better in determining what is there and what is not.
#6 IamSherwood OFFLINE
  • 8,390 Thanks
Posted April 30, 2013 - 07:10 PM
These are abit dirty, but maybe they'll help.
They're from a MF8Executive.
I'll look for more.
  • wvbuzzmaster and IHCubGuy have said thanks
#7 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted April 30, 2013 - 07:11 PM
I had only taken a pc to show it set in there, I will go get another picture and load it in here.
#8 IamSherwood OFFLINE
  • 8,390 Thanks
Posted April 30, 2013 - 07:16 PM
Choke
#9 IamSherwood OFFLINE
  • 8,390 Thanks
Posted April 30, 2013 - 07:20 PM
Solenoid.
#10 IHCubGuy OFFLINE
IHCubGuy
  • 1,500 Thanks
  • 1,579 posts
Posted April 30, 2013 - 07:23 PM
Here is a kohler manual download for a k161.  The throttle linkage is the same between the two engines.
page 19 of the download shows how it hooks up and the page after it shows how the carb and governor hook together and adjust.
Edited by IHCubGuy, April 30, 2013 - 07:26 PM.
#11 IamSherwood OFFLINE
  • 8,390 Thanks
A bit of brazing, tin work.
Ooops, going down memory lane. Sorry...
#12 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted April 30, 2013 - 07:27 PM
Here you go, this is a K161/K181 from a WH.
  • wvbuzzmaster, IamSherwood and IHCubGuy have said thanks
#13 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted April 30, 2013 - 07:29 PM
Can the assembly be rotated easily to go from top entry throttle cable to bottom entry?? Pics in a sec
#14 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted April 30, 2013 - 07:30 PM
#15 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted April 30, 2013 - 07:33 PM
Should be able to, just be careful the nut and arm also set the governor speed.
