My Homemade Can't Hook
4 replies to this topic
#1 Ryan313 OFFLINE
  • 3,364 Thanks
  • 5,230 posts
Posted April 30, 2013 - 05:34 PM
I have been wanting to make one of these since last summer; I had some time today so i decided to whip something up.
For the handle I found a piece of pipe that was already cut to a good length. I then cut off a couple pieces from a bent PK hitch and welded them on.
4C0DF9FD-E294-4DDF-B9DC-5B0929D73820-331
For the hook, I used a big U bolt; the arc in it was a little tight so I had to bend it open some. On one end I welded on some random piece that I had in the steel pile. The tooth was cut out of a 3/8" plate.
6871C74D-5A2B-4B14-9AFB-AF15F87C2106-331
The two pieces then simply bolt together.
85A796F7-6E6B-4A6B-A05C-AE21B88FFE86-331
Then, I went to find a big log so I could try it! I was able to roll this big tree trunk over with no trouble at all; although, it is on a bit of an incline.
A4045740-B843-4D6E-9C99-EEFCA5643F7A-331
Although it grabs onto large logs GREAT, anything smaller then 12" in diameter is a different story. The bottom of the pipe extends to far and it digs into the ground, and the log also ends up on top of the pipe.  Another problem with the smaller logs is that the tooth is at the wrong angle; I will have to add another tooth behind the other so it can grab small logs.
  • Gtractor, HDWildBill, New.Canadian.DB.Owner and 3 others have said thanks
#2 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted April 30, 2013 - 07:42 PM
Not bad, Ryan.  You'll have to start calling that a "can" hook instead of a "cant" hook, because you can make them yourself!
Ben W.
#3 Alc OFFLINE
  • 6,751 Thanks
  • 7,399 posts
Posted April 30, 2013 - 07:46 PM
Nice tool you made :thumbs:
#4 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,997 Thanks
  • 9,640 posts
Posted April 30, 2013 - 08:43 PM
That'll work good! Now make a matching peavey!
Edited by LilysDad, April 30, 2013 - 08:44 PM.
#5 Team_Green OFFLINE
Team_Green
  • 2,214 Thanks
  • 2,305 posts
Posted April 30, 2013 - 09:22 PM
A point on the end of the handle is very useful also.. Nice work btw...
