Greenhouse As Portable Garage?
10 replies to this topic
#1 Ryan313 OFFLINE
  • 3441 Thanks
  • 5250 posts
Posted April 29, 2013 - 08:25 PM
I just got an email from HF about a green house that is on sale, the first thing I thought of was how much better it would be then a portable garage! It is cheaper, and looks much stronger! The only downside is that it is opaque, but it could easily be painted.
What do you guys think? I am not going to do this (right now) but I wanted to give the idea to some others!
#2 UncleWillie OFFLINE
  • 16501 Thanks
  • 9061 posts
Posted April 29, 2013 - 08:34 PM
It would be better than nothing but those things are pretty small.
#3 NJKen OFFLINE
NJKen
  • 1362 Thanks
  • 1284 posts
Posted April 29, 2013 - 08:44 PM
I bet those panels are paper thin. And don't last very long, painted or not.
For what they are asking, you can buy lumber to build a shed that size cheaper.
#4 daytime dave OFFLINE
  • 5478 Thanks
  • 6780 posts
Posted April 29, 2013 - 08:52 PM
Ryan, what size is it?  I googled HF green houses and got two.  Neither one looked better than the portable garages I've seen around.
#5 KennyP ONLINE
  • 52022 Thanks
  • 52960 posts
Posted April 30, 2013 - 07:58 AM
I just looked at the one for $599. It's 10X12. You would have to either sink it on the ground or build a floor to get a tractor into it. Not sure if the panels would last very long if painted. And I am sure the framework wouldn't handle much weight added onto it. But it would be good for parts storage!
#6 chevyaddict83 OFFLINE
chevyaddict83
  • 24 Thanks
  • 68 posts
Posted April 30, 2013 - 08:12 AM
600 $$$$$????? I'm building a shed 8x12, 8ft tall before roof, for under 400, not including shingles. Buying everything from a local sawmill, except for the 3/4 plywood.
Sent from my 416-8
#7 TAHOE OFFLINE
TAHOE
  • 8514 Thanks
  • 5931 posts
Posted April 30, 2013 - 08:59 AM
I had a coworker buy one of their cheap greenhouses to use as a hot house for starting veggies. He said the first 40 mph wind turned it into big a big pretzel of scrap metal. He had it anchored to ground even.
#8 [email protected] OFFLINE
[email protected]
  • 1302 Thanks
  • 1416 posts
Posted April 30, 2013 - 09:14 AM
Painting the panels are a no-no for many reasons. The heat build-up in a green house with-out proper ventilation would make it a oven, so storage of things could be a concern, never mind trying to work in one.
  • Alc and JDBrian have said thanks
#9 JDBrian OFFLINE
  • 9679 Thanks
  • 14162 posts
Posted April 30, 2013 - 10:36 AM
I may be looking for a portable garage as well and my initial thought is that it would be more expensive to make a greenhouse than a shelter of the same size. You could always try to make a hoop house out of pvc conduit and cover it with tarps or plastic if you really wanted something cheap. That's what many gardeners do to make a dIY greenhouse.
#10 JD DANNELS OFFLINE
JD DANNELS
  • 3791 Thanks
  • 3907 posts
Posted April 30, 2013 - 10:47 AM
Ryan: Google "Quick Hoops". I think the bender runs around $60 and uses the tubing to make Chain Link Fence.
A strong energetic young man like you could probably sell enough hoops to make the shelters you want free.  And you might even make some money to boot.
#11 Ryan313 OFFLINE
  • 3441 Thanks
  • 5250 posts
Posted May 01, 2013 - 08:43 AM
I thought that it would have cost more to build a wooden shed! I also thought that the greenhouse would be stronger then what you guys are telling me. Oh well, it was just an idea. :D
