Lift Rod Help
7 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,272 Thanks
  • 1,746 posts
Posted April 28, 2013 - 09:02 PM
The rear lift rod on the 410 connects to nothing. Is flopping around under the dash. I looked on parts tree and still fact figure out were it goes or what parts I may be missing.
Sent from my HTC One VX using Tapatalk 2
#2 skunkhome OFFLINE
skunkhome
  • 322 Thanks
  • 455 posts
Posted April 30, 2013 - 07:52 PM
I believe it attaches directly to the rock shaft.
2fe8dc4df58a3d2ae60060a994cbf9cc_zps4c6b
Edited by skunkhome, April 30, 2013 - 08:05 PM.
  • BairleaFarm said thank you
#3 BairleaFarm OFFLINE
BairleaFarm
  • 1,272 Thanks
  • 1,746 posts
Posted April 30, 2013 - 08:27 PM
That's a more complete picture than what I've got. Looks like I may only be missing a turn buckle.
#4 BairleaFarm OFFLINE
BairleaFarm
  • 1,272 Thanks
  • 1,746 posts
Posted May 06, 2013 - 06:06 PM
My number 1 isn't like that. Hmm
#5 yardiron OFFLINE
yardiron
  • 23 Thanks
  • 78 posts
Posted May 24, 2013 - 01:38 AM
I don't have a pic, but on my 416S the front end of the rod is just a 90 degree bend with a washer and cotter pin, attached to a square arm welded onto the lift arm shaft. In the rear, its got a barrel with a pin on one side which the rod slides through, its secured with a pair of lock nuts. It allows the rod to pull upward but not apply any down force.
There is no turnbuckle or threads up front.
#6 sammiefish OFFLINE
sammiefish
  • 8 Thanks
  • 26 posts
Posted May 25, 2013 - 08:09 AM
the pic above is the 300 series...
maybe this will help...:
#7 BairleaFarm OFFLINE
BairleaFarm
  • 1,272 Thanks
  • 1,746 posts
Posted May 25, 2013 - 11:07 AM
Nope. My lift rod must not be original. I've given up on this for the time being. Thanks
#8 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted May 29, 2013 - 08:28 PM
I don't think he 300 series is the same, mine is not, if you want I can send pictures, I have both a 416 shuttle and 416 Hydro
