410 With Tiller Questions
7 replies to this topic
#1 BairleaFarm ONLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted April 28, 2013 - 09:00 PM
I have a hard time viewing manuals on my phone so my question is... What size belt do I need for the tiller? What size pulley needs to be on the tractor?
Sent from my HTC One VX using Tapatalk 2
#2 sammiefish OFFLINE
sammiefish
  • 8 Thanks
  • 26 posts
Posted April 29, 2013 - 03:09 PM
the pulley on the bgb is 5" OD
I would physically measure to be sure but i seem to remember something about
an HA type belt at 96.1"
Edited by sammiefish, April 30, 2013 - 08:26 AM.
#3 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted April 29, 2013 - 04:42 PM
an HA type belt at 83.8"
I believe it's a 96.1" HB belt Chris.
  • sammiefish said thank you
#4 BairleaFarm ONLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted April 29, 2013 - 09:49 PM
What's ha or HB? I haven't heard that before.
#5 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted April 30, 2013 - 04:40 AM
HA and HB are agricultural belt designations.
#6 sammiefish OFFLINE
sammiefish
  • 8 Thanks
  • 26 posts
Posted April 30, 2013 - 08:26 AM
sorry, you are right...!!  I looked up some pics i had when i physically measured mine
The length I measured is 96.75". The belt i bought is 96"
i changed my post above so someone doesnt get screwed up...
here was my highly technical method of measurement.... using some romex
to run around the pulleys   : )
Edited by sammiefish, April 30, 2013 - 01:09 PM.
#7 OkieGt OFFLINE
OkieGt
  • 1,432 Thanks
  • 1,447 posts
Posted May 30, 2013 - 10:16 AM
I would be careful using actual measurements in ordering belts, many don't measure to what they are supposed to be, same with tires, I believe the 96.1 was right. and 5/8" wide fully covered
#8 BairleaFarm ONLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 30, 2013 - 11:37 AM
I used the one mentioned. Out got the job done. However I mount this tiller next year will determine my belt. I usually use whatever gets the best bit.
