John Deere 318 Hydraulic Problems
5 replies to this topic
#1 johndeere332-us OFFLINE
johndeere332-us
  • 2 Thanks
  • 7 posts
Posted April 28, 2013 - 12:49 PM
Hey guys need some help. My 1983 John Deere is sick! On the two hydraulic values the inside one is suppose to push all the way forward to float! But mine will not! What should I look for, or just pull the valve out and rebuild? Only 1000 hours on the tractor.
#2 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted April 28, 2013 - 12:55 PM
The linkage may be gummed or rusted. Sounds like it needs to be pulled apart and cleaned up.
#3 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted April 28, 2013 - 03:54 PM
As said, you need to check the linkage and if it is tight and free then the problem could be the valve detent is stiff. As a last resort you may have to pull the valve apart but try these other things first.
#4 johndeere332-us OFFLINE
johndeere332-us
  • 2 Thanks
  • 7 posts
Posted April 28, 2013 - 05:31 PM
Cat385B & JDBrian
thanks for your input, will try this tonight and let you know later or in the am
#5 johndeere332-us OFFLINE
johndeere332-us
  • 2 Thanks
  • 7 posts
Posted April 28, 2013 - 07:33 PM
Ok cleaned linkage all up, but still will not go into float! This sucks.
#6 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted April 29, 2013 - 12:07 AM
Okay, time to tear into it then. Remove the belly screen and get in there. Make sure you have a clean area so you can find any parts that drop out of there. I bet the detent ball is gunked.
