Need Help On Power Max Onan 20Hp
ignition electronic points
11 replies to this topic
#1 zbend OFFLINE
zbend
  • 13 Thanks
  • 13 posts
Posted April 27, 2013 - 05:15 PM
I am thinking of putting a electronic ignition of the Onan, 1980 model.  If I put the magnet for the trigger on the flywheel will it work?  The thing would fire every cycle.  Is there a post where this has been done?
Thanks  Mike
#2 olcowhand ONLINE
  • 40,332 Thanks
  • 31,168 posts
Posted April 27, 2013 - 06:04 PM
The later model Onan engines have a trigger ring under the flywheel & have a waste spark, so your plan will work if set up properly.  I know of no post where anyone has done it as of yet.
  • zbend said thank you
#3 jms180 ONLINE
jms180
  • 1,462 Thanks
  • 1,538 posts
Posted April 27, 2013 - 08:24 PM
Please someone correct me if i am wrong. The coil will need to be changed to a P series coil.
Edited by jms180, April 27, 2013 - 08:30 PM.
#4 olcowhand ONLINE
  • 40,332 Thanks
  • 31,168 posts
Posted April 27, 2013 - 08:47 PM
I think he's talking about putting a home brew system together, much like is done with Tecumseh HH engines when the expensive NLA electronic ignitions go down.  The coil needed would depend on the type system installed.
#5 jms180 ONLINE
jms180
  • 1,462 Thanks
  • 1,538 posts
Posted April 27, 2013 - 08:51 PM
Thanks Daniel for helping me out I missed that part.
#6 Paulcurtis3 OFFLINE
Paulcurtis3
  • 6 Thanks
  • 8 posts
Posted April 27, 2013 - 09:28 PM
Please post the results if you try this. I'm sure others would like to switch if this works.
#7 zbend OFFLINE
zbend
  • 13 Thanks
  • 13 posts
Posted April 28, 2013 - 08:24 AM
I am looking at the Pertronix unit for cars.  They are about $80. and consist of the magnet ring ,electronic module and mounting hardware for whatever car .  The module is small and fits inside the cars distributer.  I am thinking of taking one magnet out of the ring and mounting it on the flywheel,mounting the module where the magnet will pass close and trigger the module.  I hope to use the Onan's coil.  The module just replaces the points .  If I buy one I will play with it and see if it will fire the coil.
Thanks for all the replys and info.
Mike
  • Alc and jms180 have said thanks
#8 olcowhand ONLINE
  • 40,332 Thanks
  • 31,168 posts
Posted April 28, 2013 - 11:11 AM
I wouldn't remove a magnet from the flywheel, that is if you are speaking of the ones that power the stator, as you need all of them there for proper charge capacity.  A tiny rare earth magnet would do fine & not affect the balance of the flywheel.
This ebay seller lists several sizes & shapes:  http://www.ebay.com/...=item43baca8d4d
  • Alc and zbend have said thanks
#9 zbend OFFLINE
zbend
  • 13 Thanks
  • 13 posts
Posted April 28, 2013 - 09:14 PM
I was going to remove a magnet from the ring of magnets that comes with the ignition module.  There are 8 in the ring for an 8cyl car.
Thanks for the link.
Mike
#10 olcowhand ONLINE
  • 40,332 Thanks
  • 31,168 posts
Posted April 28, 2013 - 09:15 PM
Mike
Oh I see what you meant now, sorry for the confusion.
#11 zbend OFFLINE
zbend
  • 13 Thanks
  • 13 posts
Posted April 28, 2013 - 09:28 PM
So a spark on the exhaust stroke will not be a problem?
Mike
#12 olcowhand ONLINE
  • 40,332 Thanks
  • 31,168 posts
Posted April 29, 2013 - 08:41 AM
Mike
No, not at all.  :thumbs:
Also tagged with one or more of these keywords: ignition, electronic, points
