Flo-Jet Carb Tap
5 replies to this topic
#1 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,436 Thanks
  • 2,860 posts
Posted April 26, 2013 - 10:34 PM
I have been looking high and low around localy for a 5/16 32 NEF tap for the main jet (emulsion tube) hole an the flo-jet 2 piece carb. I stumbled across the Briggs Part # 19245. It includes a 1/4 - 32 NEF tap for the low idle jet as well. Listed as $ 15.95 internet price. Most small engine guys I have talked to said that once the threads are stripped they are ruined. One old guy as well as a member or two here have stated that you can save the carb by retaping it. I have two that are stripped and I want to try to save them. They are like hens teeth around here. No one has any used or abused. I bought an engine a couple of years ago and the carb was stripped. It is the best of the two I have and I really think it can be saved. I also will order the proper screwdriver for the main jet also. Once I get them and ge them done i will let ya know how it works out. Probably should of put this with my other post for carb help. thanks. Roger.
  • akretowicz, HDWildBill, LilysDad and 1 other said thanks
#2 Lmiller3358 ONLINE
Lmiller3358
  • 1,480 Thanks
  • 1,421 posts
Posted April 27, 2013 - 06:25 AM
Do you have a True Value Hardware store in your area, my local store carries taps but they keep the specialty taps behind the counter for some reason, I'd suggest seeing if they have a blunt tap in that size also ....
  • hamman said thank you
#3 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted April 27, 2013 - 07:02 AM
This link might help you out, :thumbs:
http://www.carbrescue.com/
  • hamman, akretowicz, Lmiller3358 and 1 other said thanks
#4 hamman OFFLINE
hamman
  • 6,436 Thanks
  • 2,860 posts
Posted April 27, 2013 - 07:30 AM
Our Local True Value and Ace don't have them. I am going to order them from Briggs and get two Rebuild kits also. Thanks John for the CarbRescue.com tip. I am going to contact them on a couple of Marvel Shebler carbs for our Allis Chalmers WC tractors we have. I appreciate the help. Roger.
  • John@Reliable said thank you
#5 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted April 27, 2013 - 08:17 AM
Isn't John such a nice guy..
Dick
  • John@Reliable and hamman have said thanks
#6 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted April 27, 2013 - 12:23 PM
Dick
thatswhat.gif :bigrofl:
