Transmission Oil, Mf10
transaxle transmission oil leak
20 replies to this topic
#16 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted April 27, 2013 - 08:50 AM
Timken seal match is # 471643
  • HowardsMF155 said thank you
#17 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted April 27, 2013 - 09:00 AM
Here is a Timken Seal interchange chart attached, and I will add it to the manual section also.
#18 CMBelyea OFFLINE
CMBelyea
  • 2 Thanks
  • 12 posts
Posted April 28, 2013 - 08:51 PM
Hey, thanks everyone. This is really helpful input. I feel like a putz now, blaming someone before me. I'll try to change that oil as soon as I can. Deals may have to wait; there's a busy summer awaiting my 10s.
And Amigatec, right after I got the first MF10 I found your you tube channel and watched all if the episodes regarding your MF10 restoration. They were tremendously useful. I was almost heartbroken to see it blowing oil after you got it reassembled. I hope you were able to clear that up.
  • Amigatec said thank you
#19 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted April 28, 2013 - 09:09 PM
I changed all the oils in my Sears last week. Farmers often refer to that color as "Calf scour yellow" and is definitely water.
I also made rain caps to put over the shifters on most of the tractors. Find an old inner tube and cut a 6" or so circle. Make a 1/4" hole it the middle and (after taking off the knob) slide it down below the tin work. Just make sure it will do it's job without being in the way of anything. Also make sure it's puckered up, not down like a funnel
On these older (higher tolerance) trannies that aren't being run in sub zero temps, I have gone to 80w-90 oil and been very happy.
Advanced Auto has the best (non special order) price around here. 5 gal pail was $55. That is 10 less than TSC
#20 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2029 Thanks
  • 3172 posts
Posted April 28, 2013 - 11:31 PM
Thanks I still haven't gotten to the oil problem, I plan to finish this summer.
#21 CMBelyea OFFLINE
CMBelyea
  • 2 Thanks
  • 12 posts
Posted May 01, 2013 - 08:02 PM
Calf-scour yellow. I'll look for that next time I'm in paint at Home Depot.
Also tagged with one or more of these keywords: transaxle, transmission oil leak
