Transmission Oil, Mf10
transaxle transmission oil leak
20 replies to this topic
#1 CMBelyea OFFLINE
CMBelyea
  • 2 Thanks
  • 12 posts
Posted April 26, 2013 - 10:08 PM
Thought I had an engine oil leak, but upon inspection I saw oil dripping off the transaxle case. Crawled underneath and saw transmission oil all over the side of the frame and the frame-half of the driven pulley.
So I read up in the manual, and thought I'd pull the transaxle level plug out and see what happens. Holy bat-crap, look at how much came out! It must have taken 10 minutes to drain down to the level plug.
Kinda looks like pancake batter or egg nog.
#2 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1036 Thanks
  • 1457 posts
Posted April 26, 2013 - 10:13 PM
Wow!!! That is terrible looking oil. Transmission oil changes always seem to get overlooked. You figure out where it was leaking from?
#3 CMBelyea OFFLINE
CMBelyea
  • 2 Thanks
  • 12 posts
Posted April 26, 2013 - 10:16 PM
And HERE'S where the leak that kicked this all off was...jeez, out was about coming out of it's ears.
#4 CMBelyea OFFLINE
CMBelyea
  • 2 Thanks
  • 12 posts
Posted April 26, 2013 - 10:19 PM
That's the rear pulley shaft with the idler pulley on the right side of the frame.
#5 HowardsMF155 OFFLINE
  • 3107 Thanks
  • 3091 posts
Posted April 26, 2013 - 10:33 PM
Are you planning on putting in a new oil seal?  Also, in the picture where you show it draining, that actually looks like the level check plug.  There should be a plug right down on the bottom of the transmission where you drain it all out.  Or did I mis-interpret what I saw?
PS The good news is, you probably don't have a leak at the axle seal!
Edited by HowardsMF155, April 26, 2013 - 10:34 PM.
#6 CMBelyea OFFLINE
CMBelyea
  • 2 Thanks
  • 12 posts
Posted April 26, 2013 - 10:45 PM
I wasn't planning to, but now I don't know! You didn't mis-interpret. As you surely know, you're only supposed to add trans oil until it starts coming out there. THAT'S how much additional was put in by the previous owner/"mechanic". And yeah, I'm tickled that I might not have to take that back end apart.
#7 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2029 Thanks
  • 3172 posts
Posted April 27, 2013 - 02:21 AM
That looks like water in the oil, you better drain it and flush it. Mine was like that, to flush it I just filled it with 30 wt and run it around.
#8 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted April 27, 2013 - 06:43 AM
:ditto:  Definitely looks like water in that oil.
How does that much water get in there?
#9 IlovemyCub OFFLINE
IlovemyCub
  • 172 Thanks
  • 204 posts
Posted April 27, 2013 - 06:49 AM
Looks like my tranny fluid before I replaced it, good luck with her! Ian
#10 HowardsMF155 OFFLINE
  • 3107 Thanks
  • 3091 posts
Posted April 27, 2013 - 06:58 AM
I'm wondering if that's how much WATER has made it's way in over the years.
#11 pwombles OFFLINE
pwombles
  • 203 Thanks
  • 220 posts
Posted April 27, 2013 - 07:00 AM
The cast will condensate inside in weather changes, and if the fluid is NEVER changed, then the water keeps building up. I agree, thats a lot of water! Not sure if all of it was from condensation, but some probably was.
#12 Amigatec OFFLINE
Amigatec
  • 2029 Thanks
  • 3172 posts
Posted April 27, 2013 - 07:01 AM
Some of it is from condensation, and some is probably from sitting in the rain, and water running down the gearshift.
#13 ckjakline OFFLINE
ckjakline
  • 1192 Thanks
  • 1177 posts
Posted April 27, 2013 - 07:15 AM
After seeing that makes me want to check my oil condition.
#14 Amigatec OFFLINE
Amigatec
  • 2029 Thanks
  • 3172 posts
Posted April 27, 2013 - 07:17 AM
The gear shift is a good place for water to get in.i have seen people rubber seals to slip over the stick to help keep the water out.
#15 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted April 27, 2013 - 08:44 AM
You need to go ahead & replace that seal.  It will still leak, but likely not as bad with new oil.
Agco part #
833910M1   Seal, Oil (3/4 x 1-5/8 x 5/16")
You can take the measurements to a good bearing supply business or even an auto parts house & they can match it up.
Also tagged with one or more of these keywords: transaxle, transmission oil leak
