31 Tiller Turns Backwards?
8 replies to this topic
#1 rainman_210 OFFLINE
rainman_210
  • 22 Thanks
  • 16 posts
Posted April 26, 2013 - 08:52 PM
Hello guys, a few weeks ago i posted a question on how/what i needed to attach a 31 tiller to my rf 112. I want to thank everyone again for the questions that i had answered. Since that time i have mounted the my 31 tiller onto a 212. this afternoon as i dropped it into the ground for the first time i noticed that it throws the dirt back twoards the tractor, and the dull edges of the tines are doing the digging, not the sharp edges. These symptoms tell me the tiller might be turning backwards and i cannot think of why. This would be the first garden tractor tiller i have owned and am wondering what would cause the tiller to turn backward. i feel like the belts are on correctly, it runs smooth and quiet.....any advice woukld be great thanks........appologize for no pics on this topic
#2 olcowhand ONLINE
  • 42,896 Thanks
  • 31,938 posts
Posted April 26, 2013 - 09:16 PM
I am not familiar at all with this tiller, but could someone have swapped the tine sets side to side?  That or could the gearbox have been messed with inside? Many gearboxes can be reversed by swapping which side the gears sit on the shafts.
#3 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted April 26, 2013 - 10:03 PM
Did you put a half twist in the long belt that runs from the intermediate drive pulley back to the tiller? If not, you have to do this.
#4 rainman_210 OFFLINE
rainman_210
  • 22 Thanks
  • 16 posts
Posted April 26, 2013 - 10:27 PM
i did not put a half twist in the long belt....what does a half twist do for operation of the tiller?
#5 jdslednut OFFLINE
jdslednut
  • 680 Thanks
  • 851 posts
Posted April 26, 2013 - 11:15 PM
Reverses the direction!  Pretty sure that should end your dirt throwing problems.  There is a certain direction to put the half twist in though.  I have to check out the manual each time I do it.
This thread might help.
http://www.weekendfr.../17/244003.html
Edited by jdslednut, April 26, 2013 - 11:18 PM.
  • MH81 and johndeereelfman have said thanks
#6 MH81 OFFLINE
  • 29,978 Thanks
Posted April 26, 2013 - 11:33 PM
Half twist or figure 8 belt usage is to change direction. Sounds like Troy knows.
#7 JohnDeere214 OFFLINE
JohnDeere214
  • 57 Thanks
  • 67 posts
Posted April 27, 2013 - 06:09 AM
Yea twist the belt 1/2 turn clockwise(from the front of the tractor) before installing on the mule drive............
#8 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted April 27, 2013 - 07:21 AM
:reading_the_manual:  Yep, not only a knee pad sometimes :D
P.S. Had a JD snowblower that did this too, read the book 3 or 4 times to get it right.
Edited by John@Reliable, April 27, 2013 - 07:22 AM.
#9 olcowhand ONLINE
  • 42,896 Thanks
  • 31,938 posts
Posted April 27, 2013 - 08:19 AM
Didn't know they ran figure 8's in the belts!  Not seen that used myself in many many years.
