Jd 210
16 replies to this topic
#16 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted May 05, 2013 - 12:31 PM
When working on the deck reinforcement, I needed to remove the spring loaded deck mount lock pins on the front of the deck.  I wish I had taken the camera, but raining so hard & felt it wise to leave it in the house.  Moisture plays heck with it.  Anyways, instead of roll pins or large cotter pins holding the spring/pin assemblies in place, someone had put in fence post staples, then bent the sharp ends together!
Here's a rep pic of a fence staple. ]
That's as bad as using a bolt on the top of a caster wheel!
#17 olcowhand ONLINE
  • 41,192 Thanks
  • 31,428 posts
Posted May 05, 2013 - 01:06 PM
The bolts don't come out...staples will!
