K321 Carb Gasket
5 replies to this topic
#1 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted April 25, 2013 - 01:08 PM
My carb was flooding so I tookit apart and installed new kit asfter cleaning . My question is my kit came with a ring bowl gskt and another flat gskt with a d shaped hole do I use both gskts ? When I took my carb apart it only had ring gskt .
larryd
  • JRJ said thank you
#2 olcowhand ONLINE
  • 41,216 Thanks
  • 31,437 posts
Posted April 25, 2013 - 01:23 PM
Yes, the ring gasket first, then the flat gasket.  You have to install the ring gasket, then lay the flat gasket over it, then install your float & needle.  Center the flat gasket, then install & tighten the bowl.  I believe the flat gasket serves to prevent gasoline from bouncing up into the vent in rough conditions.
  • KennyP, LilysDad, larryd and 2 others have said thanks
#3 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted April 25, 2013 - 01:25 PM
Daniel nailed it! (again) :D
  • larryd said thank you
#4 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted April 25, 2013 - 01:37 PM
Thanks guys Back to the shop now
larryd
#5 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted April 25, 2013 - 03:33 PM
Damn-you guys are good.
Dick
#6 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted May 04, 2013 - 07:57 AM
I set the float before I install the gaskets.  I is easier for me, not having the gaskets in the way with the 11/64" drill bit
found this site Disassembly, Cleaning and Repair of Kohler Adjustable Carb used on K Series and Magnum Engines
http://outdoorpoweri...arb_4705315.asp
lot of good info there
