Ariens Gt 3 Point Hitch Fabrication Opinion
6 replies to this topic
#1 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted April 25, 2013 - 08:02 AM
Im Going To Start Fabricating A 3 Point Hitch Fo My Gt 17 Was Thinking Of Doin A Category 1 Anyone Think That Might Be To Much
#2 Cat385B ONLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted April 25, 2013 - 08:07 AM
It's a lot easier to find cat 1 attachments for sure. The only issue I think you would run into is sizing. Box blades made for category one, for example, would be heavier and would be tough to pull with the Ariens. Blades and discs would be fine, imo.
#3 Rock farmer OFFLINE
Rock farmer
  • 1,197 Thanks
  • 1,232 posts
Posted April 25, 2013 - 02:05 PM
I wouldn't even consider it. I have class 1implements. Even if you could attach them, the tractor could not work them.
If you really want to use class one attachments, buy a class 1tractor.
Joe
#4 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted April 25, 2013 - 02:31 PM
I'm curious why wouldn't category one work on that tractor
#5 HowardsMF155 OFFLINE
  • 2,841 Thanks
  • 2,979 posts
Posted April 25, 2013 - 02:45 PM
A Massey Ferguson 135, a rather small cat one tractor for it's day, weighs between 3500 and 4000 lbs and has a 35-40 hp engine.  Field discs and scrapper blades and plows that were cat one would tend to lift the front end of the tractor.  The lift capacity of the three point links was just under 3000 lbs.   While I'm sure the tractor you have is quite capable, it just isn't in the same league as a cat one tractor.  Use cat 0 stuff, it is more appropriatley sized.  If you are having trouble finding cat 0 stuff, try making an adapter for regular Brinly sleeve hitch stuff.
  • Rock farmer and IlovemyCub have said thanks
#6 shorty ONLINE
shorty
  • 5,290 Thanks
  • 5,170 posts
Posted April 26, 2013 - 04:16 AM
I am thinking that you might lose lifting height. Every heavier class of hitch is set a bit higher with the pin heights on the attachments matching. You might not be able to get your attachment lifted to nice travel height. Just my 2 cents.
#7 shorty ONLINE
shorty
  • 5,290 Thanks
  • 5,170 posts
Posted April 26, 2013 - 06:13 PM
Got to thinking about this today. Are you hoping to use cat 1 attachments or are you building your lift this way for more travel? Somewhere I read of some one getting cat 1 lift for their Ariens. If I remember right they were still using cat 0 equipment. The longer lower arms will give more height travel, but also sets the weight farther behind the axle.
