Paint Problem
15 replies to this topic
#1 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,966 Thanks
  • 9,613 posts
Posted April 24, 2013 - 06:14 PM
I have some small parts that I want to paint with Rustoluem Bar b que paint. This needs to be baked after it is dry. The oven is obviously out because of the smell. Any ideas how to pull this off?
  • larryd said thank you
#2 KennyP ONLINE
  • 37,397 Thanks
  • 45,448 posts
Posted April 24, 2013 - 06:19 PM
Wait till Mama goes shopping?
  • Craig., IamSherwood, LilysDad and 2 others have said thanks
#3 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted April 24, 2013 - 06:27 PM
Just get a old oven and put it outside. I have one out in the shed that the burners don't work, but the oven does. Use it for canning and what ever else.
  • LilysDad said thank you
#4 Cat385B OFFLINE
    HAZMAT CAT
  • 13,778 Thanks
  • 9,918 posts
Posted April 24, 2013 - 06:28 PM
Over an open fire pit? On the grill? Laid on top of the muffler of the truck?
#5 IamSherwood OFFLINE
  • 8,390 Thanks
Posted April 24, 2013 - 06:30 PM
Wait till July, and take it to Texas..
  • Texas Deere and Horse, Craig., New.Canadian.DB.Owner and 3 others have said thanks
#6 NJKen OFFLINE
NJKen
  • 1,361 Thanks
  • 1,284 posts
Posted April 24, 2013 - 06:32 PM
I'll lend you my daughters easy bake oven if that will help. It gets hot enough to bake a cake.
Or like suggested, maybe use a grill ? A gas grill would work great and can be adjusted to keep a steady temp, plus it's outside
EDIT: And what ever you do, don't try heating them parts up in a propane fired turkey deep-fryer indoors.
Edited by NJKen, April 24, 2013 - 06:42 PM.
  • New.Canadian.DB.Owner and LilysDad have said thanks
#7 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted April 24, 2013 - 06:59 PM
Toaster oven?
  • Craig. and LilysDad have said thanks
#8 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,966 Thanks
  • 9,613 posts
Posted April 24, 2013 - 07:47 PM
I guess the fire pit will be the best bet. Maybe inside a container?
#9 HydroHarold OFFLINE
HydroHarold
  • 703 Thanks
  • 977 posts
Posted April 24, 2013 - 09:12 PM
Not knowing the size or number of parts... If I were without any alternative heating methods and if I was scared of my wife, I think I might try a heat gun.  It might take a while, but you can generate a decent heat if the part is inside a container and away from the blast of the blower.  An oven thermometer inside with the parts would be a big help. (Maybe she' would let you use just the thermometer?):D
#10 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted April 25, 2013 - 12:44 AM
I am with some of the others, I would use a as grill and monitor the temp really close.
#11 HydroHarold OFFLINE
HydroHarold
  • 703 Thanks
  • 977 posts
Posted April 26, 2013 - 11:38 PM
I painted some grab hooks for my FEL yesterday and they set inside an 8"X10" cardboard box all night with an 85w light bulb in a reflector clamp lamp shining down into the box.  Not a "bake job", just a warming to enhance the drying.
#12 UncleWillie ONLINE
  • 15,516 Thanks
  • 8,703 posts
Posted April 27, 2013 - 01:22 PM
Find a couple of heat lamps from a restaurant supply house.
#13 whst400 OFFLINE
whst400
  • 25 Thanks
  • 29 posts
Posted April 29, 2013 - 11:20 PM
The Easy Bake idea may have been meant as a joke, but the concept would work. They are really only an enclosed space that uses the heat from an incandecent light bulb to bake. A large box turned upside down over your parts with a drop light under it would do it.
#14 916 hydro OFFLINE
916 hydro
  • 114 Thanks
  • 139 posts
Posted May 04, 2013 - 08:26 AM
come to my neghborhood someone has a used oven in the front yard theyd let you borrow
#15 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,966 Thanks
  • 9,613 posts
Posted May 04, 2013 - 10:30 AM
Are you sure they aren't planting flowers in it?
