Is This An Economy?
18 replies to this topic
#1 TimW OFFLINE
TimW
  • 419 Thanks
  • 273 posts
Posted April 23, 2013 - 10:37 PM
I purchased it from the original owners son.  It has a Wisconsin AEN with a hand clutch that dates 1955 by serial numbers.  It looks pretty original and was said to run a couple of years ago.  Any ideas or thoughts would be greatly appreciated.  I don't want to mess with it until I find out more about it.
#2 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted April 23, 2013 - 10:39 PM
Might want to to say its an early economy?
  • TimW said thank you
#3 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted April 23, 2013 - 10:47 PM
It deffintly looks like an economy at first glance, but I don't think so. The lift lever, front axle and steering box/ column are economy, but nothing else looks economy. It looks like a very well made home brew machine.
  • 14,889 Thanks
  • 15,514 posts
Posted April 23, 2013 - 10:49 PM
It kinda looks like the rear end of a Shaw, I think it's a very well built Home brew!!
#5 boyscout862 ONLINE
  • 13,554 Thanks
  • 9,430 posts
Posted April 23, 2013 - 10:59 PM
It looks as though it is made from a bunch of car parts. Some of the small companies used surplus auto parts to save time and money when building their tractors. It could be from a small company or a really good home built. Either way it is a treasure.
#6 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,598 Thanks
  • 2,909 posts
Posted April 24, 2013 - 05:39 AM
I thought it looked like an early gilson. I remember as a kid in the 60s using a neighbors to spread a lot of gravel. That one had a tiller steering though, Nice tractor. good find,
#7 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted April 24, 2013 - 06:36 AM
I would vote for economy Parts on it, yet frame is heavier metal and bigger pieces and the bull gear boxes LEAN and that is diff than economy. Trans could be from one, but used in lots of brands, and there is no bellhousing which economy should have had with the clutch in it. Economy's did have Wis engines at times. Also the brakes with pedals on each side don't appear right for economy. Early ones like this old would have had hand brakes OR No brakes even. That Blade would HAVE to GO in my opinion. Too close to tractor to turn it and that would be big issue.
#8 hamman OFFLINE
hamman
  • 6,598 Thanks
  • 2,909 posts
Posted April 24, 2013 - 06:42 AM
Gibson ( early) ??
#9 Guest_gravely-power_*
  • Guests
Posted April 24, 2013 - 06:47 AM
Definitely not an economy. Looks home brew. STILL, a very nice tractor and worth restoring.
Economy's used T-92 transmissions. That is not a T-92. Also those bull gears are not economy.
That being said. After the war (2nd big one) there were 100's of start up "assemblers" of garden tractors trying to cash in on the new garden and home building boom. This could be one of those.
Edited by gravely-power, April 24, 2013 - 06:53 AM.
  • Alc, boyscout862 and TimW have said thanks
#10 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted April 24, 2013 - 07:35 AM
i say homemade kinda looks like an old ford rear end and somekind of automotive gear box.
#11 AV430 OFFLINE
AV430
  • 53 Thanks
  • 130 posts
Posted April 27, 2013 - 11:39 AM
First off, very cool tractor! I believe this tractor is an unstyled Economy of the late 50's, or a Red-E model 15 from the same era. Many of the tractors from this era share components. Not a definitive identification but definitely from this "tribe" and not homemade in my opinion.
#12 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted April 28, 2013 - 09:40 PM
There is only a few parts on that tractor that look like a direct bolt on from an Economy.The first Economy's were home made and they would likely have been classified as home made if they would not have went into production.This might have been intended to go into production but for some reason did not.Welding equipment was scarce and sub par back then so using welds to determine if a tractor was home made is not a determining issue for me.Just look at the welds on some of those early ones.
#13 Guest_gravely-power_*
  • Guests
Posted April 29, 2013 - 10:05 AM
On the contrary. Welding, arc welding, at the end of the 2nd world war already had a 30+ year history. There were thousands of experienced welders looking for work at this time. Not to mention the 1000's of sub contractors that were now starving for business and were competing for sales.
#14 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted April 29, 2013 - 10:19 AM
Have you seen some of the welds on the early Economy tractors?
#15 Guest_gravely-power_*
  • Guests
Posted April 29, 2013 - 11:28 AM
I will post pictures later. I own 9 economy/Power king/Jim Dandy tractors.
