Crank Save Pt2 Pics
5 replies to this topic
#1 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted April 23, 2013 - 07:51 PM
I had some time tonight to work on it. We left off with it sitting in the vise cooling down after a second application of brazing. I attempted just to fill up the areas that were damaged. In hindsight I should have put a coating on the entire area where the damage was instead of just in spots. I missed a few spots and didnt get enough in others.
The first set of pics show the braze and then the file work where i removed the heavy stuff. I filed the heavy stuff off and as it got down to a thin coating, I eased up on the file pressure. I was trying to take small bites so not to damage the shaft.
  • Arti said thank you
#2 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted April 23, 2013 - 07:55 PM
After a the file work, a heavy coating of valve grinding compound was applied to the area. Then the flywheel set down on the shaft and worked back and forth and round and round.
DSCF2980.JPG DSCF2979.JPG DSCF2978.JPG DSCF2977.JPG DSCF2976.JPG DSCF2975.JPG DSCF2974.JPG DSCF2972.JPG
#3 chris m OFFLINE
chris m
  • 3,336 Thanks
  • 4,061 posts
Posted April 23, 2013 - 07:58 PM
Great job! Thanks for the update. That will work just fine. I don't see any reason it won't. :thumbs:
#4 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted April 23, 2013 - 08:04 PM
I had a few file marks left so another heavy coating of valve compound was applied and the process done again.
Not including the brazing I have about 1hr tied up in the filing and fitting. I know its not a perfect repair but I think that with the lapping, there is more surface area contact than there was originally. I would definitely suggest that the flywheel be lapped in during a rebuild. If there is no warpage to the crank,I think we have an economical way to save a crank.
It will be a while before I am able to test for warpage, but when I do i will post results.
#5 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted April 23, 2013 - 09:02 PM
Great job, I think that'll do just fine.
#6 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1,088 Thanks
  • 1,284 posts
Posted April 24, 2013 - 01:44 AM
Great job....now I'm off to find Part 1 of this topic. Thanks for sharing.
