Dirt Scoop Question?
4 replies to this topic
#1 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted April 23, 2013 - 11:09 AM
I have a King Kutter 3 point dirt scoop and in general if I like it.
It has one quirk that aggrevates me in that loaded the latch is difficult to trip.
There is a tube, piece of pipe that the lever rides on. It is not welded that I can see.
I'm wondering if I loosen the bolt through it so it can roll if it would not work better?
#2 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted April 25, 2013 - 07:27 PM
well right or wrong, I took the bolt out greased it andput it back in so it can turn.
#3 KennyP ONLINE
  • 41,455 Thanks
  • 47,383 posts
Posted April 26, 2013 - 05:22 AM
I hope this helps. I've not had the opportunity to see one of these close up, so not sure what you were talking about on the latch. Lube can't hurt it.
#4 Gtractor ONLINE
Gtractor
    the homeless tractor hoarder
  • 9,955 Thanks
  • 5,145 posts
Posted April 26, 2013 - 09:18 PM
On my Ferguson scoop I have to keep the latch oiled or its hard to trip.  I just give it a shot of oil every time I hook it up to the tractor.
#5 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted April 30, 2013 - 09:16 AM
Yes I pulled the bushing greased the through bolt and greased the bushing. I used the heck out of the scoop to move material and really like it. But if this does not fix it I might reconfigure the trip latch to gain some Mechanical advantage.
