I Think You'd Call This A "tow Tractor"
24 replies to this topic
#1 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1,089 Thanks
  • 1,284 posts
Posted April 23, 2013 - 12:53 AM
This would be a really cool attachment to have if you had tractors that you needed to haul around or move from place to place. Never seen anything like it but it sure does make sense.
  • MH81, hamman, KennyP and 5 others have said thanks
#2 jd.rasentrac ONLINE
jd.rasentrac
  • 4,807 Thanks
  • 4,302 posts
Posted April 23, 2013 - 02:32 AM
For the "big" tractors I know such a construction between the hydraulic lift and the front drawbar.
  • Moosetales and larryd have said thanks
#3 Lmiller3358 ONLINE
Lmiller3358
  • 1,547 Thanks
  • 1,458 posts
Posted April 23, 2013 - 04:02 AM
That's cool, I hope he's not repossessing that GT
#4 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted April 23, 2013 - 06:34 AM
Now look what you did! You've got me thinking now that I've got to have one!
Ben W.
#5 KennyP ONLINE
  • 40,943 Thanks
  • 47,132 posts
Posted April 23, 2013 - 06:46 AM
That's cool. I think he's on to something!
#6 IamSherwood OFFLINE
  • 8,395 Thanks
Posted April 23, 2013 - 06:51 AM
Great idea, but I think it needs to be beefed up quite a bit.
In the last 2 seconds of the vid, it looks like the tubes that he slides in are bent down.
The outter arms look awefull small, and probably twisted.
  • MH81 and larryd have said thanks
#7 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted April 23, 2013 - 06:59 AM
Well a course it is, look at what he's towing :D  all American steel, not some stamped steel half plastic tractor :( :thumbs:
  • MH81, Moosetales and larryd have said thanks
#8 NJKen OFFLINE
NJKen
  • 1,362 Thanks
  • 1,284 posts
Posted April 23, 2013 - 07:27 AM
I'd like to see him turn or try to back up with that set up. Me thinks it would not work very well doing either.
Edited by NJKen, April 23, 2013 - 07:27 AM.
#9 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted April 23, 2013 - 10:02 AM
i could use one of those for moving non running gt's around
#10 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted April 23, 2013 - 10:56 AM
Great idea for a project
larryd
  • Moosetales said thank you
#11 Oo-v-oO OFFLINE
Oo-v-oO
  • 341 Thanks
  • 448 posts
Posted April 23, 2013 - 06:50 PM
That is essentially a copy of a wheel lift on a wrecker.
He needs to incorporate a pivot point between the wheel lift section and the 3-point mounts, so the combination can turn without the front wheels popping out of the lift pockets.
  • KennyP and Moosetales have said thanks
#12 UncleWillie ONLINE
  • 16,257 Thanks
  • 8,975 posts
Posted April 23, 2013 - 08:00 PM
Only problem with that is if the rear end is locked up. There were a couple that we hooked up to the crane to move out of that shop last month and with the rear seized  the DragonFly wouldn't pull them in muddy places. It got to where it was easier to just pick up the whole tractor.
#13 xshooter OFFLINE
xshooter
  • 34 Thanks
  • 93 posts
Posted April 23, 2013 - 08:33 PM
I started building something like that a couple months ago, just been too busy to get it finished. I'll post pics when I get it done.
Edited by xshooter, April 23, 2013 - 08:33 PM.
#14 Moosetales OFFLINE
Moosetales
  • 1,089 Thanks
  • 1,284 posts
Posted April 23, 2013 - 08:43 PM
So which one of you guys is going to be the one that builds this contraption better and stronger than depicted in the video? Once you do, please share your plans so the rest of us can follow suit.
#15 OldBuzzard OFFLINE
OldBuzzard
  • 7,097 Thanks
  • 4,816 posts
Posted April 23, 2013 - 10:31 PM
Saw a Cub Cadet setup for towing at the Wellington, OH show last Sept.  It was done up right  :D :D :D
  • IamSherwood said thank you
