8" Plow
11 replies to this topic
#1 DH1 ONLINE
DH1
    Electric Tractors
  • 5,242 Thanks
  • 5,552 posts
Posted April 22, 2013 - 08:57 PM
Got me an 8" plow tonight, not sure what make it is, any ideas?
  • MH81 and boyscout862 have said thanks
#2 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted April 22, 2013 - 09:00 PM
Nice score Doug, I am thinking Simplicity walk behind or similar.
  • DH1 and boyscout862 have said thanks
#3 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted April 22, 2013 - 09:13 PM
Ditto on the walk behind: the adjusting handle would be hard to use from the seat of tractor.
#4 timtractor OFFLINE
timtractor
  • 224 Thanks
  • 376 posts
Posted April 22, 2013 - 09:23 PM
I have a plow that looks like that which goes on my Montgomery Ward walk behind.
#5 DH1 ONLINE
DH1
    Electric Tractors
  • 5,242 Thanks
  • 5,552 posts
Posted April 22, 2013 - 09:31 PM
Question?
Can this
Be mounted to the plow so it can be used with a sleeve hitch?
#6 Jlaws OFFLINE
Jlaws
  • 554 Thanks
  • 368 posts
Posted April 22, 2013 - 11:54 PM
Doug , I would think you could use  that Brinly sleeve yoke on your 8 " plow , you may have to redrill the rear hole in your plow beam as the hole centers may be different .
Another thing to consider is ,  I think the Brinly yoke is made of 5/8 " thick steel where it bolts to the beam , I'll have to measure one of mine to make sure,  how wide is it between the two beams on your plow ?
I have an Ohio Steel plow which is similar to a Brinly , but the yoke is only made of 1/2 " thick material where it attaches to the beam .
Edited by Jlaws, April 23, 2013 - 12:01 AM.
  • DH1 said thank you
#7 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted April 23, 2013 - 05:40 AM
Doug, it's a Simplicity #990024 plow. Here's the instructions and parts list for it:
http://gardentractor...4-990025-plows/
  • DH1, MH81 and Craig. have said thanks
#8 DH1 ONLINE
DH1
    Electric Tractors
  • 5,242 Thanks
  • 5,552 posts
Posted April 23, 2013 - 07:02 PM
Today after work I spent a little time on the plow, everything is seized that is suppose to turn but with some effort, penetrating oil, heat, I was able to free everything up, the depth adjuster was the hardest to loosen up and the threads on it are damaged. Good enough to work but ???.
I took the Yoke off the 10" Brinly and it is thicker than what the 8" plows beams are, but they spread out enough that it's going to work. Need to enlarge 1 hole and drill the 2nd, just like Jaws said above.
The moldboard itself is rusted real good so I need to smooth that out, I'll use and angle grinder with a coarse cup shaped knotted wire wheel.
All in all it's looking like it's going to work on my sleeve hitch tractors.
Here's a good picture of a nice one like mine, looks almost the same, I don't have the yoke and mine is a 8" picture is a 6.5"
  • olcowhand and MH81 have said thanks
#9 MH81 OFFLINE
Posted April 23, 2013 - 08:32 PM
Doug, the yoke on most are twisted 10*... At least the Brinly plows are. Does this yoke give you the twist?
#10 olcowhand ONLINE
  • 40,365 Thanks
  • 31,175 posts
Posted April 23, 2013 - 08:36 PM
Doug, this would be the perfect plow to use on the Electric Massey.  10" is quite a pull, but this 8"er would allow longer battery life, and still make a good furrow.
#11 DH1 ONLINE
DH1
    Electric Tractors
  • 5,242 Thanks
  • 5,552 posts
Posted April 23, 2013 - 08:37 PM
The yoke that it comes with I don't have and don't know if it does.
The yoke I'm putting on it is from a Brinly 10" sleeve hitch plow and I hoping it works.
Going to bring both my plows to your plow day just in case it doesn't.
Edited by DH1, April 23, 2013 - 08:37 PM.
  • wvbuzzmaster said thank you
#12 DH1 ONLINE
DH1
    Electric Tractors
  • 5,242 Thanks
  • 5,552 posts
Posted April 23, 2013 - 08:38 PM
That's what I'm hoping for, I want it to work.
